NEED HELP REGARDING BOUNDARY CONDITIONS!!!!urgent
@faraaz-faisal-34Q3wy
1.6K
hi hello everybody my thesis is "finite element analysis of jacketed columns subjected to axial load only"
i have used the SHEIKH AND UZUMERI MODEL and theoretically found out the confined axial load capacity of random size jacketed columns (stirrups confining pressure increases the axial capacity inferred)
i have also verified the same in ANSYS by modelling the columns with
concrete- solid 65 element
steel- link8 element
boundary conditions- one end free where load is applied as equivalent static pressure
other end hinged
i got the correct result in software but my sir is telling the column will not be stable,,i told that since we are check only axial capacity , hinged or fixed are same...
plz give ur valuable advice about this.. thank you
other end hinged
