Need help on REST client communicating with remote server
micheal john
@micheal-john-l1fIn3 โ€ข Oct 26, 2024
Hi guys,
Projects initial requirements is to create a client to communicate with a REST web service server(remote server) using jersey,
i want to create a CLIENT REQUEST HEADER which contains following parameters in same order.
Request PATTERN:
1)GET(method)
2)URL domain(remote)
3)URL path
4)date field(date and time)
5)access key(public key)
6)accept field(application/xml or application/json)
amateur code:
Client client = Client.create();
WebResource webResource =client.resource(url);
ClientResponse response = webResource.queryParam("Date", timeStamp+" GMT")
.header("Authorization", requestAuthKey)
.accept(MediaType.APPLICATION_XML_TYPE)
.get(ClientResponse.class);
๐Ÿ˜€
  • Manish Goyal
    @manish-r2Hoep • Feb 10, 2014
    A very nice explanation for your Problem.
    I don't know anything about this language, but it is clear you are passing request parameters in incorrect way
  • micheal john
    @micheal-john-l1fIn3 • Feb 10, 2014
    Manish GoyalA very nice explanation for your Problem.
    MultivaluedMap<String, String> queryParams = new MultivaluedMapImpl();
    queryParams.add("q", "stuff"); //set parametes for request
    Client client = Client.create(config);
    client.addFilter(new LoggingFilter(System.out));
    com.sun.jersey.api.client.WebResource.Builder builder = webResource
    .queryParams(queryParams).header("x-date", timeStamp+" GMT")
    .accept(MediaType.APPLICATION_XML);
    for this i'm getting 500 "internal server error"
  • micheal john
  • Manish Goyal
    @manish-r2Hoep • Feb 11, 2014
    Try to turn on debug level, it will show you actual error,
  • micheal john
    @micheal-john-l1fIn3 • Feb 12, 2014
    @#-Link-Snipped-#, i tried debbuging for 2 long days and now i arrived at solution.
    problem was my machine time was not synchronized with the server.
    thanks you
  • Manish Goyal
    @manish-r2Hoep • Feb 12, 2014
    Good to hear that, Please share what did you learn from this problem, I mean How did you find this problem that it is something related to sync time between machine time
