Need help in FYP title.(VRF versus chilled water system)
limseisei
@limseisei-EdOdQn โ€ข Oct 21, 2024
HI, I received a title for FYP,it's the use of Variable Refrigerant Flow (VRF) air condition system in the large building in comparison to conventional air conditioning system (chilled water).However, i have no idea how to start.Do I need to do a simulation for comparison or any nicer idea?
  • limseisei
    @limseisei-EdOdQn • Oct 11, 2009
    @thebigk • Oct 11, 2009
    Didn't get you. What do you mean by 'received a title'? Maybe its a good idea to get in touch with the people who selected the project for you and ask them to define the scope & limitation of the project.
    Say what? ๐Ÿ˜€
  • Aashish Joshi
    @aashish-VrevFC • Oct 12, 2009
    Doing a simulation would be a good touch, but don't make it the main stay of your project..You will need to compare the two methods theoretically as well..Here is a pdf from ashrae:
  • limseisei
    @limseisei-EdOdQn • Oct 12, 2009
    yeah,the main purpose is to compare the two methods theoretically.I'm worry that it is too research base.So,I wondering any other method for deeper comparison.Anyway,thanks for your reply.
  • Aashish Joshi
    yeah, your topic may require a bit of research..but you will get a lot of help from ashrae and IEEE journals..You may find them in your college library, or at the British Council Library
  • gohm
    @gohm-F3UUpP • Oct 13, 2009
    ASHRAE is a great group & should provide you with lots of contacts and assistance. They had a booth at a convention I was at as well as some educational sessions on new and grenn technology.
