    @thebigk • Sep 10, 2014
    Dear #-Link-Snipped-# - We'd really love to see your attempt at the code. Don't worry even if it's wrong. Please share it so that the expert coders here can help you fix it. It'll be a great learning for you as well.
    @anoop-kumar-GDGRCn • Sep 10, 2014
    What is next number?? is it 15101051?
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Sep 10, 2014
    anksingla1
    11
    121
    1331
    14641
    can anyone tell the code of this pattern.??
    First show us what you have done so far?
  • anksingla
    @anksingla-ttYJbX • Sep 10, 2014
    Yeah right
    Anoop KumarWhat is next number?? is it 15101051?
  • anksingla
    Sanyam KhuranaFirst show us what you have done so far?
    i am using net on my phone...can't show you the code that i tried..
  • Sanyam Khurana
    anksinglai am using net on my phone...can't show you the code that i tried..
    No problem, show us the code when you can and then we would help ๐Ÿ˜€
    We are in no hurry. Take your time.
  • Manish Goyal
    @manish-r2Hoep • Sep 10, 2014
    Very Simple Program,
    Simple Loop, and then a single line if you know multiplication
  • anksingla
    Manish GoyalVery Simple Program,
    Yeah this program is a simple multiplication of 11 but I was asked this in different way..
    numbers b/w two 1's is the sum of two numbers of above line..like in 121 2 is sum of 11 which is above of 121...
    can we made the logic of this pattern in this way..???
    anksinglaYeah right
    Oops.... next number will be 161051.
    #-Link-Snipped-# , has provided you the right solution. ๐Ÿ˜‰
  • anksingla
    Anoop KumarOops.... next number will be 161051.
    I forgot to mention that question is not multiplication of 11..
    the question I asked is to find the
    "the no's b/w the two 1's is the sum of two no's of above line like in 121 2 is sum of 11 & similarly in 1331 first 3 is sum
    of 12 & second is 21 of 121"...
    @ramani-VR4O43 • Sep 10, 2014
    One way of looking at multiplying by 11 is 'Shift and Add'. In effect adding ten times the number to the number.
    Put zero in front and at the end of a number that is 0110 for 11. Start adding pairs from the right: 1+0 = 1 which becomes the rightmost digit of the answer. then 1+1 = 2, the second digit and finally 0+1 = 1 the third digit giving the result 121.
    This is the method called 'add the neighbour' by Trachtenberg in his teatise on speed mathematics.
    Is this what you are getting at?
  • anksingla
    A.V.RamaniOne way of looking at multiplying by 11 is 'Shift and Add'. In effect adding ten times the number to the number.
    yes...but I didn't got the right code for this.
    can u tell what's the code for this??
  • pritambu
    @pritambu-kjLgzG • Sep 11, 2014
    Implement this code and run:
    <SNIPPED>
    @thebigk • Sep 11, 2014
    #-Link-Snipped-# - You suddenly made all of us look idiot. Also, the code you've provided has been copied from <a href="https://forgetcode.com/CSharp/1030-Pascal-triangle-programming" target="_blank" rel="noopener noreferrer">Error - Forget Code</a>
  • pritambu
    Yes because that code is working and giving the correct output.
  • Vishal Sharma
    @vishal-pysGmK • Sep 16, 2014
    pritambuYes because that code is working and giving the correct output.
    Wow! ๐Ÿ˜•
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Sep 17, 2014
    Standing ovation for you!
    You made all of us look idiots ๐Ÿ˜€
