need help for my project work
the initial billet height is 13mm and dia 20mm my question is in how many stages i.e sequence of operations can we do this to get 14mm inner dia and 14mm depth
Member • Feb 26, 2011
the knowlage of the material property is must , such as yeild stress ,ductility, elastic modulus of the material you are going to use .gsk_ssiti am doing bearing cup using cold forging i.e backward extrusion process
Member • Feb 27, 2011
Member • Feb 28, 2011
Member • Mar 24, 2011
ya we use 2combined blades having 15 degree angle at each side but it is not enough to lift.or we have to use heavy power supply which increase its weight.....which create a great problem.ishutopreHave you tried for existing ones? Why don't you connect them symmetrically? for example if you use 3 blades you can have them 120 degrees apart. The more important fact you must consider is what will be various angles so that the blades produce greater lift.
The less number of wings you use the better but it will only require more power to be developed. 😀
