My pc's date changed every time when it restart..help
Saminder
@saminder-vN74ry • Oct 26, 2024
Hi,
I am having a problem from the past few days.Whenever I switched on my pc ,I see that my system's date is changed to the 2004 March.
For solving this I have installed a new CMOS battery but the result is same.
Can anyone tell me to get rid out from this problem??😕
  • just2rock
    @just2rock-DkmPtO Mar 20, 2009
    Saminder,
    I will request you to check your BIOS settings...maybe clock is getting reset
    @thebigk Mar 20, 2009
    I guess there's a setting for date in BIOS as well. Have you tried checking options in BIOS?
  • just2rock
    Saminderhow to stop resetting the clock ?
    Can you please explain me in detail.
    As already i suggested ,check BIOS clock setup, manually fix it to the current DD/MM/YY format & save the changes by pressing F10 or as par your motherboard save option & then restart OS
  • Saminder
    @saminder-vN74ry Mar 20, 2009
    I have tried it but can't able to change the date through BIOS .
    Do you know any solution through jumper settings?
  • rahul_sid
    @rahul-sid-B8isOC Mar 21, 2009
    hey buddy may be ur cmos battery is damaged in ur motherboard which is required for the clock function.
  • Saminder
    @saminder-vN74ry Mar 21, 2009
    I have already tried this solution .😔
  • Saminder
    @saminder-vN74ry May 1, 2023
