Motor Overload Protection
I am using an electric hoist to pull a metal mandrel into a metal casing. Daily around 10 mandrels are pulled and pushed. Sometimes 1 out of hundred casing is under size which makes the mandrel tight to pull and makes the motor overloaded, hence the motor either breaks the wire or its winding damaged itself. What i want is an overload protection for the motor, i mean a kind of tripping mechanism which trips the motor mains line when the ampere goes more than say 10 ampere or 8 ampere wherever we set the value..
So what apparatus is to be used for such kind of work?
