motor controllers.
zaveri
zaveri
@zaveri-5TD6Sk Oct 23, 2024
So can anyone tell me how a controller for a PMDC motor is used.
How is it connected to the motor and what are the parameters that it can control.
What are the general specifications these controllers have ?
    Harshad Italiya
    @harshad-ukH5ww May 21, 2012
    Are you talking about BLDC motor control?
  • Abhijeet Khandagale
    Abhijeet Khandagale
    @abhijeet-gu2Sj7 May 21, 2012
    i use L298/3. one end is for logic input from controller. other is for motor analog output. speed, direction and enable can be controlled. google those ICs. need any help, get in touch.
    Abhijeet Khandagale
    also specify what motor you are using. can be answered better.
  • zaveri
    zaveri
    @zaveri-5TD6Sk May 21, 2012
    Well i am going to use 12 volt 56 amp permanent magnet dc motor. can you explain the concept of these motor controllers in detail.
    whats BLDC
    Abhijeet Khandagale
    please specify the use. that one is a heavy duty i guess. you will require a different motor driver. they work on a circuit called the H bridge. will share a article. BLDC is brushless DC motor.
  • zaveri
    zaveri
    abhijeetkhan
    well i am not gonna use BLDC.
    we are building an electric car, and this motor is going to power it. now i am looking for a controller which will control its speed as well as direction of rotation. i also want to know how this controller can be interfaced to the accelerator pedal.
    Abhijeet Khandagale
    now we're talking! will have to do a bit of research on it. haven't worked on high amp motors. give me some time.
  • zaveri
    zaveri
    ok dude take your time.
    Abhijeet Khandagale
    google H Bridge.
  • aarthivg
    aarthivg
    @aarthivg-HH344f May 22, 2012
    zaveri
    Speed of permanent magnet dc motor can be controlled by varying the voltage applied to the armature. Feedback devices sense motor speed and send this information to the control to vary its output voltage up or down to keep speed at or near the set value.
    Feedback techniques include voltage tachometers, optical encoders, electromagnetic pulse generators,
    and back emf monitoring. And by using thyristor firing pulse controller, voltage can be controlled.
    P.S: correct me if I am wrong
    Abhijeet Khandagale
    @abhijeet-gu2Sj7 May 22, 2012
    #-Link-Snipped-# that's theory. what he needs is a practical solution. controllers are available in the market. need to hunt them that's all.
  • zaveri
    zaveri
    @zaveri-5TD6Sk May 22, 2012
    you are right , but right now the motor is gonna be controlled manually, and will not incorporate any of that mechatronics stuff.
  • zaveri
    zaveri
    @zaveri-5TD6Sk May 25, 2012
    ok one last thing, for a 12volt motor, what should be the voltage range for the controller ?
    Ramani Aswath
    @ramani-VR4O43 May 25, 2012
    This may give you some pointers:
    Abhijeet Khandagale
    @abhijeet-gu2Sj7 May 25, 2012
