missing "pulse" detector
Lem0nHead
@lem0nhead-ekdAZa โ€ข Oct 25, 2024
hello
I want to do something similar to a missing-pulse-detector, but I want it to detect also steady signals
so I basically want to output high when the input is not switching up/down (up is around 1 second, down may be from 0.3s to 10s... but it doesn't need to be so exactly because it just should trigger if it's not switching for more than 15 seconds)
I'm trying to avoid using a microcontroller, so maybe 555 can do that?
input:
_--_--___--_--______________--___--_-----------------_--_--
output:
______________________-----_________________------______
    @harshad-ukH5ww • May 28, 2009
    So you want to monitoring the Input Pules Continue?
  • Lem0nHead
    @lem0nhead-ekdAZa • May 28, 2009
    godfatherSo you want to monitoring the Input Pules Continue?
    yes
    summarizing
    the output should go high if the input is steady high or low for more than 15 seconds
    then the output goes down again when it switches
    Why not you use Microcontroller is there any restriction?
  • Lem0nHead
    godfatherWhy not you use Microcontroller is there any restriction?
    no
    I just find it easier if it's possible with one or two 555, if it's possible
    otherwise I'd need to get a programmer board and learn to program
    yes let check out first that is it possible with 555 or not... and one more thinh buddy programming of Controller is not too much difficult.
