Microsoft NetMeeting
Communications with NetMeeting include chatting in real time, using web cams and/or microphones for video and voice communications, using an electronic whiteboard, and even sharing programs. Users can work collaboratively across the globe on graphics, documents, or proposals, without ever having to leave their office.
NetMeeting is no longer an application that is installed by default
Where Is NetMeeting?
You likely don’t know where NetMeeting is, and if you look for it, you probably won’t find it either.
To install and run NetMeeting and make it available on your computer:
1. Click Start | Run and type conf. Click OK.
2. In the NetMeeting dialog box, click Next to work through the wizard and install the program. If you’ve previously installed it, NetMeeting will start automatically.
3. As you work through the wizard, you’ll be required to:
-Fill in the information for name, e-mail address, etc.
-Select Microsoft Internet Directory as the default.
-Select the connection speed.
-Choose whether or not to place a shortcut on the Desktop.
[FONT="]-[/FONT]Test and configure your microphone, if one is installed.
