@raksh001-Q7kOOU • Jan 14, 2010
kingslydear CE ans,
I want to know how the freezing point of water and meting point of ice can ba same 0 degree Celsius.how can both happen at the same point.Water and ice at 0 degree remain at equillibrium.
@vega-Ic42ds • Jan 15, 2010
During the process of conversion of ice into water, at zero degrees celcius, heat provided is used to convert ice into water and not to raise the temperature. So temperatue will not rise from Zero degrees unless all ice is converted into water.
@yadavundertaker-0p3HBs • Jan 15, 2010
it is because of latent heat of fusion...as if latent heat of fusion is added to the equilibrium then ice will change to water at O c....and if this heat is removed then water will change into ice at O c.....
kingsly OP
@kingsly-3Vo9Ow • Jan 15, 2010
thanks #-Link-Snipped-#
@gauravbhorkar-Pf9kZD • Jan 16, 2010
VegaDuring the process of conversion of ice into water, at zero degrees celcius, heat provided is used to convert ice into water and not to raise the temperature. So temperatue will not rise from Zero degrees unless all ice is converted into water.
That heat is called Latent heat.
