Master Cylinder
abarth23
@abarth23-Ks5MvH โ€ข Oct 26, 2024
if i have rear wheels car with a diagonal split the pressure in the 2 lines is the same?if i measure this 2 output lines i must find the same pressure?
and in this car how must be the front-rear percentage?
  • gohm
    @gohm-F3UUpP • Mar 27, 2009
    Do you mean the brake master cylinder? The master cylinder for hydraulic brakes supplies the brake fluid for all four calipers.
  • abarth23
    @abarth23-Ks5MvH • Mar 27, 2009
    yeah i mean the brake master cylinder.because i want to measure the braking line pressure. if i set a pressure valve in one of the two lines is ok? or i must to set up for both?
  • gohm
    @gohm-F3UUpP • Mar 28, 2009
    Have it downstream from the master cylinder/booster.
    Try here for some further info:
    <a href="https://www.automotiveforums.com/t75152.html" target="_blank" rel="nofollow noopener noreferrer">Vehicle Brake Information (very long) - Car Forums and Automotive Chat</a>
  • Dan68
    @dan68-QLflNH • Apr 5, 2009
    you are going to have to look at what size rotors and calipers you have on the vehicle. the location of your centre of gravity and obviously the weight on each wheel. then aim to lock the wheels up
