looking for chlorine/methane reactions
dear friends i m new member looking for ur fast help
i need information about the reaction of chlorine and methane in wastewater treatment
Anil PachpandeHi,
I know about chlorine reaction in waste water. Its like chlorine reacts with water to form hypochlorous acid.
H2O + Cl2 ----> HOCl + HCl
This HOCl helps in desinfection / oxidation of impurities. It destroys algae, minerals, dust & material causing odour, colour, turbidity etc..
... Sorry, I am not much aware of methane reaction.
π -
flowershi freind
thanks for ur replay, its a simple information and i know it. please if u have any more about this subject.
i need ebooks and lectures and any websites dealing with this subject
thanks alot -
LazarusLong
General Reactions:flowershi freind
thanks alot
chlorine/methane reactions - Yahoo Search Results
waste water treatment:
Probably more to the point:
3.2.2 Primary treatment
The objective of primary treatment is the removal of settleable organic and inorganic solids by sedimentation, and the removal of materials that will float (scum) by skimming. Approximately 25 to 50% of the incoming biochemical oxygen demand (BOD5), 50 to 70% of the total suspended solids (SS), and 65% of the oil and grease are removed during primary treatment. Some organic nitrogen, organic phosphorus, and heavy metals associated with solids are also removed during primary sedimentation but colloidal and dissolved constituents are not affected. The effluent from primary sedimentation units is referred to as primary effluent. Table 12 provides information on primary effluent from three sewage treatment plants in California along with data on the raw wastewaters.
Table 12: QUALITY OF RAW WASTEWATER AND PRIMARY EFFLUENT AT SELECTED TREATMENT PLANTS IN CALIFORNIA
Quality parameters (mg/l, except as otherwise indicated) βCity of Davis βSan Diego βLos Angeles County Joint Plant βRaw wastewater βPrimary effluent βRaw wastewater βPrimary effluent βRaw wastewater βPrimary effluent βBiochemical oxygen demand,BOD5
112 β73 β184 β134 β- β204 βTotal organic carbon
63.8 β40.6 β64.8 β52.3 β- β- βSuspended solids
185 β72 β200 β109 β- β219 βTotal nitrogen
43.4 β34.7 β- β- β- β- β
NH3-N
35.6 β26.2 β21.0 β20.0 β- β39.5 β
NO-N
0 β0 β- β- β- β- β
Org-N
7.8 β8.5 β- β- β- β14.9 βTotal phosphorus
- β7.5 β- β10.2 β- β11.2 β
Ortho-P
- β7.5 β11.2 β
- β
pH (unit)
7.7 β- β7.3 β7.3 β- β- βCations:
Ca
- β- β- β- β78.8 β- β
Mg
- β- β- β- β25.6 β- β
Na
- β- β- β- β357 β359 β
K
- β- β- β- β19 β19 βAnions:
SO4
- β
160 β
270 β
Cl
- β
120 β
397 β
Electrical conductivity, dS/m
2.52 β2.34 β
2.19 β- βTotal dissolved solids
- β- β829 β821 β1404 β1406 βSoluble sodium percentage, %
- β
- β
70.3 β
Sodium adsorption ratio
- β- β- β- β8.85 β6.8 βBoron (B)
- β- β- β- β1.68 β1.5 βAlkalinity (CaCO3)
- β- β- β
322 β332 βHardness (CaCO3)
- β
- β
265 β
Source: Asano and Tchobanoglous (1987)βIn many industrialized countries, primary treatment is the minimum level of preapplication treatment required for wastewater irrigation. It may be considered sufficient treatment if the wastewater is used to irrigate crops that are not consumed by humans or to irrigate orchards, vineyards, and some processed food crops. However, to prevent potential nuisance conditions in storage or flow-equalizing reservoirs, some form of secondary treatment is normally requiredinthese countries, even in the case of non-food crop irrigation. It may be possible to use at least a portion of primary effluent for irrigation if off-line storage is provided.
Primary sedimentation tanks or clarifiers may be round or rectangular basins, typically 3 to 5 m deep, with hydraulic retention time between 2 and 3 hours. Settled solids (primary sludge) are normally removed from the bottom of tanks by sludge rakes that scrape the sludge to a central well from which it is pumped to sludge processing units. Scum is swept across the tank surface by water jets or mechanical means from which it is also pumped to sludge processing units.
In large sewage treatment plants (> 7600 m3/d in the US), primary sludge is most commonly processed biologically by anaerobic digestion. In the digestion process, anaerobic and facultative bacteria metabolize the organic material in sludge (see Example 3), thereby reducing the volume requiring ultimate disposal, making the sludge stable (nonputrescible) and improving its dewatering characteristics. Digestion is carried out in covered tanks (anaerobic digesters), typically 7 to 14 m deep. The residence time in a digester may vary from a minimum of about 10 days for high-rate digesters (well-mixed and heated) to 60 days or more in standard-rate digesters. Gas containing about 60 to 65% methane is produced during digestion and can be recovered as an energy source. In small sewage treatment plants, sludge is processed in a variety of ways including: aerobic digestion, storage in sludge lagoons, direct application to sludge drying beds, in-process storage (as in stabilization ponds), and land application.
3.2.5 Disinfection
Disinfection normally involves the injection of a chlorine solution at the head end of a chlorine contact basin. The chlorine dosage depends upon the strength of the wastewater and other factors, but dosages of 5 to 15 mg/l are common. Ozone and ultra violet (uv) irradiation can also be used for disinfection but these methods of disinfection are not in common use. Chlorine contact basins are usually rectangular channels, with baffles to prevent short-circuiting, designed to provide a contact time of about 30 minutes. However, to meet advanced wastewater treatment requirements, a chlorine contact time of as long as 120 minutes is sometimes required for specific irrigation uses of reclaimed wastewater. The bactericidal effects of chlorine and other disinfectants are dependent upon pH, contact time, organic content, and effluent temperature.
3.2.7 Reliability of conventional and advanced wastewater treatment
Wastewater reclamation and reuse systems should contain both design and operational requirements necessary to ensure reliability of treatment. Reliability features such as alarm systems, standby power supplies, treatment process duplications, emergency storage or disposal of inadequately treated wastewater, monitoring devices, and automatic controllers are important. From a public health standpoint, provisions for adequate and reliabile disinfection are the most essential features of the advanced wastewater treatment process. Where disinfection is required, several reliability features must be incorporated into the system to ensure uninterrupted chlorine feed.
flowersthanks alot my friend for ur help.
its useful information for me .
hi everyone...
i hv recntly joined d gang of "d crazy engg".
wl,can anybody of u can help me wth sum easiest code for the following
conversions in STACK.
1....
Which is the good book for electrical science and engineering chemistry for b tech 1st and 2nd semester
hello friends,
could any one of you tell me how to protect a folder/file using DOS ?
πThanks in advance for you answers.π
Hi all ,, my name is maysaa , 4th year , comm. eng. , my FYP is about GSM and i need an idea about a good project about GSM...
helloooooooooooooooooooooooooooooooooooooooooooooooo
