LG Introduces Minibeam Portable LED Projectors PF1500 And PW800
Aditya Deshmukh
Aditya Deshmukh
@aditya-deshmukh-wKCSZt Oct 26, 2024
South Korean electronics maker LG just introduced two new products in its LED projectors range. According to the LG press, these new products are portable projectors that will come under the Minibeam range. This time LG has focused on the portability and durability of the projectors. PF1500 and PW800 are the two new debutants of the Minibeam series. Both projectors are manufactured for different purposes. Let's go through some of the product specifications and find out how they are different from each other.
The first product in the Minibeam lineup is the PF1500 model or as it is alternatively Minibeam Pro. This is the top-line model and it can deliver an output with Full HD (1920 x1080) resolution. Speaking of the projection capability, this one can project diagonals up to 120 inches which is a fairly big projection and has a optical zoom functionality which can enlarge a image with a 1.1 factor. The brightness of PF1500 projector is 1400 ANSI lumens. This projector can mirror your phone, tablet or laptop wirelessly and it also supports sound via bluetooth pairing which saves the hassle of complicated wired setup of sound systems. PF1500 has very compact dimensions - 132 x 220 x 84mm and weighs around 1.5 Kg.
LG_Minibeam
The second product on the list is the PW800 which has a different focus area because it has a TV tuner built inside and thus named as Minibeam TV. Minibeam TV has a low output resolution than Minibeam pro which is 1280 x 800 pixels and it can project diagonals upto 100 inches. Brightness of PW800 is of 800 ANSI lumens. This well equipped projector is more compact and light weight than Minibeam Pro and it weighs only 0.6 Kg with dimensions set at 140 x 140 x 50mm.
Moving to the durability, LG claims that both these projectors have same life time of 30,000 hours, which translates to 10 years if they are used 8 hours daily. They will be available in US and Korean market by this month and rest of the world will get these in coming weeks. Price of PF1500 is 999 USD as per the listing on Amazon and price of PW800 is confirm yet. What are your views on these portable projectors? Share your views through comments in the comment section below.
  • M.A.KHAN
    M.A.KHAN
    @makhan-xaTthZ May 27, 2015
    The problem with LG Projectors is that their image size (diagonal) is very less i,e it is only 3meter that too in its latest model PF1500, in rest of its model it is just 2.5 meter. The price range of LG Projectors starts from 50000 INR. In this price BenQ offers you its model GP 20 which has 6.99 meter diagonal projection image.And GP 20 is also LED lamp.
  • M.A.KHAN
    M.A.KHAN
    can anybody suggest a popular brand projector having LED lamp, 15000 or higher contrast 700 lumen bright, and 3 meter (diagonal) projected image under 50000 INR
  • M.A.KHAN
    M.A.KHAN
    can anybody suggest a popular brand projector having LED lamp, 15000 or higher contrast 700 lumen bright, 3 meter (diagonal) projected image miniumum WXGA (1280X800) resolution, under 50000 INR.
