KTM Duke 200 - Reviews, Please?
Europe's famous KTM has partnered with Bajaj Automobiles in India to launch the sporty motorcycle KTM Duke 200. I've been noticing that the media is talking a lot about these bikes and I decided to explore more. The bike looks good and has a sporty design. Considering 4 stroke engines as a norm for the motorcycles these days, I'm not quite sure how the bike accelerates. I've not had a test drive yet; but I'd be impressed only if it gives a better acceleration over the old 125 CC two stroke Yamaha bikes I'm in love with.
Image Credit: KTM.com
I'm also yet to find out the on-road price of the bike. Why not hear a bit more about the motorcycle from our mechanical, automobile engineers and tell us whether the bike is worth the price? If anyone has had a test drive of this bike, please share your experience with us.
KTM Duke 200 Specifications (Credit: KTM.com)
ENGINE
Design: Single-cylinder, 4-stroke, spark-ignition engine, liquid-cooled
Displacement: 200 cm³
Bore: 72 mm
Stroke: 49 mm
Starting aid: Electric starter
Transmission: 6-speed, claw shifted
Engine lubrication:Forced oil lubrication with 1 rotor pump
Primary gear ratio: 22:72
Secondary gear ratio:14:43
Cooling system: Liquid cooling system, continuous circulation of cooling liquid with water pump
Clutch: Clutch in oil bath / mechanically operated
Ignition system: Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
CHASSIS
Frame: Tubular space frame made from steel tubes, powder-coated
Fork: WP Suspension 4357
Shock absorber: WP Suspension 4618 EM
Suspension travel: Front150 mm
Suspension travel: Rear150 mm
Brake system Front: Disc brake with two-pot brake caliper
Brake system Rear: Disc brake with one-pot brake caliper, floating brake discs
Brake discs - diameter front300 mm
Brake discs - diameter rear230 mm
Chain: 5/8 x 1/4” (520) O‑Ring
Steering head angle65°
Wheel base1,361±15 mm
Ground clearance (unloaded)170 mm
Seat height (unloaded)810 mm
Total fuel tank capacity: ~10.5 liters
Unleaded premium fuel (95 RON)
Weight without fuel approx.125 kg
