@anoop-kumar-GDGRCn • Apr 21, 2012
I suppose you are using combox to populate date and then selecting it.
Initially on page load do not select anything then add following like this
<select id="Find" size="1" onchange="javascript:yourFunction()" style="position:relative;" > <option value="Anchor1">Anchor1</option> <option value="Anchor2">Anchor2</option> <option value="Anchor3">Anchor3</option> <option value="Anchor4">Anchor4</option> </select><br>
you can send pass parameter also.
then in yourFunction() javascript: add <a href="https://bytes.com/topic/javascript/answers/656764-how-redirect-page-using-javascript" target="_blank" rel="nofollow noopener noreferrer">how to redirect a page using javascript? - Javascript</a>
You can use <a href="https://www.w3schools.com/jsref/prop_loc_href.asp" target="_blank" rel="nofollow noopener noreferrer">Location href Property</a> -
@lovejeet-etHdkD • Apr 21, 2012
hey thanks for the reply, but you didn't got the question i guess. sorry if was a bit ambiguous.
it's for combo box only, where there are several entities, say x, y and z. what i want is that when user selects x, it should redirect to another page say abc.jsp, for y, it should redirect to pqr.jsp and so on.... -
what are xyz....
if these are radio buttons then just use OnClick() event and call the javascript function. -
xyz are different entities like anchor1, anchor2 in your example. n ya, onclick() method is a nice solution to that....
@praveenkumar-66Ze92 • Apr 23, 2012
Wait... Lemme say... You got a combobox with values Page 1, Page 2, Page 3. And upon selecting them, they should redirect you to One.jsp, Two.jsp, and Three.jsp accordingly. If this is the case, you can try this:
<select name="page" id="page" onchange="redirectPage(this);"> <option value="One.jsp">Page 1</option> <option value="Two.jsp">Page 2</option> <option value="Three.jsp">Page 3</option> </select> <script type="text/javascript"> function redirectPage(which) { location.href = which.value; } </script>This works in almost all the browsers. Checked just now. Try and let me know... ๐
@lovejeet-etHdkD • Apr 24, 2012
hey thanks a lot #-Link-Snipped-#. yup done. now the next problem is the drop down menu's. i want my 3rd dropdown menu to be based on the values of my 2nd menu, and dat to be dependent on the 1st one. how to do that now???
@praveenkumar-66Ze92 • Apr 24, 2012
lovejeethey thanks a lot #-Link-Snipped-#. yup done. now the next problem is the drop down menu's. i want my 3rd dropdown menu to be based on the values of my 2nd menu, and dat to be dependent on the 1st one. how to do that now???
So it means 3 individual dropdowns huh???
You mean like this? The value of the next combo box is dependent on the previous one???
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.fmsinc.com%2FMicrosoftAccess%2FForms%2Fcombo-boxes%2Fcascade2.jpg&hash=00653703511f5b58bb6c77a93b9bf788)
yup. like this. it includes dynamic selection for some dropdown menu's using database too. ๐
@praveenkumar-66Ze92 • Apr 25, 2012
lovejeetyup. like this. it includes dynamic selection for some dropdown menu's using database too. ๐
I guess its getting complicated... Then you got two choices:
1. Ajax Update
2. Page Refresh
Which one do you prefer? -
@lovejeet-etHdkD • Apr 25, 2012
i do not prefer ajax. wanna keep it as the last option. i tried it for two drop down menu's and it wasn't much tought. but when it comes to more than two and when retrieving the values from database, its all over my head....๐
If you were using ASP.net, it is damn easy... Check this out: #-Link-Snipped-#
And I saw this in StackOverflow. Seems promising. Read on...
You need to download JQuery (JavaScript framework) and include that in the head section of the HTML.
<script type="text/javascript" src="jquery.js"></script>
Inside the OnChange function for first dropdown call the function to populate the subsequent dropdowns.
$(document).ready(function()ย {The function is a s follows:
ย ย ย ย $('#DDIdParent').change(function()ย {
ย ย ย ย ย ย ย ย populateChildDropdown('DDIdParent');
ย ย ย ย });
functionย populateChildDropdown(ddId)ย {Inside your Servlet's doGet method, you will have a code like this to get the value of subsequent dropdown from the database as a JSON String:
ย ย ย ย varย ddย =ย $('#'ย +ย ddId);
ย ย ย ย $.getJSON('json/mapping?dd='ย +ย ddId,ย function(opts)ย {
ย ย ย ย ย ย ย ย $('>option',ย dd).remove();ย //ย Clearย oldย optionsย first.
ย ย ย ย ย ย ย ย ifย (opts)ย {
ย ย ย ย ย ย ย ย ย ย ย ย $.each(opts,ย function(key,ย value)ย {
ย ย ย ย ย ย ย ย ย ย ย ย ย ย ย ย dd.append($('<option/>').val(key).text(value));
ย ย ย ย ย ย ย ย ย ย ย ย });
ย ย ย ย ย ย ย ย }ย elseย {
ย ย ย ย ย ย ย ย ย ย ย ย dd.append($('<option/>').text("Pleaseย selectย theย parentย DD"));
ย ย ย ย ย ย ย ย }
ย ย ย ย });
ย ย ย ย ย ย ย ย Mapย optionsย =ย yourDao.callDatabase(parameter);You need to map the json/mapping to your servlet inside web.xml. You can also pass parameters from the jquery function if needed.
ย ย ย ย ย ย ย ย Stringย jsonย =ย newย Gson().toJson(options);
ย ย ย ย ย ย ย ย res.setContentType("application/json");
ย ย ย ย ย ย ย ย res.setCharacterEncoding("UTF-8");
ย ย ย ย ย ย ย ย res.getWriter().write(json); -
sir ji i want that in jsp, no php or .net allowed...๐
@anoop-kumar-GDGRCn • Apr 25, 2012
Without ajax you need to refresh the page.
using onChange() even submit the page with some flag. and on sevlet/ jsp, you are using, get all the values. now fetch values for next drop down menu on basis of latest dropdown menu. and come back to the page with all values. and populate the your latest dropdown menu and set all the previous values.
why not Ajax. you are just fetching data from database.๐ -
@praveenkumar-66Ze92 • Apr 26, 2012
lovejeetsir ji i want that in jsp, no php or .net allowed...๐
Sir Ji! It is JSP! ๐
And if you really know JavaScript, those things inside PHP block are JavaScripts. No where I have used PHP! Lolz... -
@prasad-aSUfhP • Apr 27, 2012
This smells like an assignment ๐
But perhaps you need to do this via simply Javascript. -
@lovejeet-etHdkD • Apr 27, 2012
@praveen- oops..... sorry that was a bit confusing by that header of 'php'. will try the code.
@kidakaka- hahaha.......yup, a part of my project only, but what all i could try was for two menu's and that to without the database. rest i need to take the help...๐ -
Here's what you do -
Declare a javascript array for the URLs.
In the dropdown, the values of each option should map to the index of this URL array.
When the form is submitted, simply invoke a function which will take the value of the dropdown, retrieve the particular URL from that value and change the location to that. -
@praveenkumar-66Ze92 • Apr 27, 2012
kidakakaHere's what you do -
When the form is submitted, simply invoke a function which will take the value of the dropdown, retrieve the particular URL from that value and change the location to that.Even then it becomes an AJAX Call right?
Nope. Its still Javascript. Why go into the trouble of AJAX?
<html> <script language="Javascript"> function doMyThang() { var urlArray = ["https://google.com","https://crazyengineers.com","https://kidakaka.com"];window.location = urlArray[document.quickUrl.urlDropdown.value-1]; } </script> <body> <form name="quickUrl"> <select name="urlDropdown" > <option value="1">Google</option> <option value="2">CE</option> <option value="3">Kidakaka</option> </select> <input type="button" value="do my thang!" onClick="javascript:doMyThang();" /> </form> </body> </html>Here's the code of what I was thinking.
