  • Is there any relay which can be programmed to work under certain voltage, current or load range?
    mrexp21
    mrexp21
    @mrexp21-p4q7uU
    Updated: Sep 10, 2013
    Views: 1.5K
    Is there any relay which can be programmed to work under certain voltage, current or load range? For example, voltage range from 0V to 10V, the relay deactivates while voltage range from 10.1V to 12V, the relay activates. This applies the same for current and load range with different value of course. Basically, the relay will read the range and activates accordingly. Thanks.
  • Akhilesh Kumar Nair
    MemberSep 14, 2013
    mrexp21
    Your specifications are interesting and complex and insufficient for me to visualize but I will advise you to either use microcontroller based system
    or
    Use extra voltage source so that along with your 10 volt signal it operate the normal contactor.
