Interesting experiments with ADSL splitter
Experiment 1
As we know, the ADSL splitter box has 1 input and 2 outputs, one for phone signal line, and the other for internet signal line
Plug the telecommunication line into the input. Then in the output lines, I make the swapping. I plug the phone line to the internet output, and the internet line to the phone output
Then I dial the phone to call to a fax number
Surprisingly, I heard the busy tone, instead of fax tone.
Note: When I connect in normal way, plug the phone line to the phone output, and internet line to the internet output, this effect does not happen. That means I heard the fax tone as usual
Experiment 2
I make the looping back from the output to the input. To do this, I cut into the cable and heal the wire inside
Then I make the looping as below
In a), I loop the net output to input, and connect phone output to a telephone machine. No signal at all
In b), I loop the phone output to input, and connect net output to a modem, this time I can access internet normally
Schema for second experiment can be found at
<a href="https://www.flickr.com/photos/80780504@N07/" target="_blank" rel="nofollow noopener noreferrer">thinhnghiem | Flickr</a>
Is it working correctly?
  • yogi.bharadwaj
    @yogibharadwaj-l2QJTU Dec 31, 2013
    thinhnghiemExperiment 1
    Experiment 2
    i think when we connect the modam pin or internet pin it is already sorted to astablish a internet connection. i think the internet connection should be astablish by twao ways first by dialup an 2nd is adsl nodem in dial up[ connection we do not require a modem and the usage charges are as per the calls and the speed is slow in other way modem is used which generates a ip address and communicate and we get high speed internet access.
  • Thinh Nghiem
    @thinh-TIntyX Jan 1, 2014
    yogi.bharadwaji think when we connect the modam pin or internet pin it is already sorted to astablish a internet connection. i think the internet connection should be astablish by twao ways first by dialup an 2nd is adsl nodem in dial up[ connection we do not require a modem and the usage charges are as per the calls and the speed is slow in other way modem is used which generates a ip address and communicate and we get high speed internet access.
    So, why the fax tone is busy in the first experiment, and phone tone is corrupt in 2 a)
