Intel-DAQRI Smart Helmet Gives You X-Ray Vision, Lets You See Through Walls
Sahil Badani
@sahil-badani-fLJODY • Oct 26, 2024
Cashing on the RealSense 3D system that it released at CES 2014, Intel has launched at the same Electronics Show a set of glasses fitted into a helmet that give an X-ray like vision.
The DAQRI Smart Helmet allows its wearer to see what is behind an item using Intel’s RealSense 3D camera. An application of Augmented Reality (AR), it gives a live view of the physical environment where the elements are provided by computer generated sensory inputs. Sounds like a bona fide sci-fi move, doesn’t it? But this has been done before, and was last seen in Microsoft’s HoloLens demonstration in 2015.
Augmented-Reality​
Primarily focused on industrial use, it provides a “human-machine interface” and inserts real-time information with reality work instructions, safety information and mapping among other things. To put it simply, it mechanically incorporates and overlays the information needed to visualise elements into the wearer’s vision; that is how AR works.
The glasses-helmet duo is powered by Intel’s 6th Gen Core m7 processor, while the onus of applying AR fell upon the virtual reality firm DAQRI. This co-developed device aims to maximize safety, productivity, and ensure the welfare of wokers in the industrial scheme of things.
Bridget Karlin, MD for Intel’s Internet of Things strategy office believes that the Smart device has been designed to solve fundamental and day-to-day problems that are faced in the industrial set-up of today. This sounds alright, when we imagine that workers and engineers will no longer have to carry papers around the workplace, a soft copy is all that will be required to send and receive the most complex diagrams, schematics and designs.
The Smart Helmet has been tested by a range of Fortune 100 companies across the industrial sector, and a fact looks established, the Intel-DAQRI product is definitely not a flash in the pan.
Source: <a href="https://www.theguardian.com/technology/2016/jan/06/intel-daqri-smart-helmet-realsense-ar-augmented-reality-x-ray-glasses-ces" target="_blank" rel="nofollow noopener noreferrer">Intel launches x-ray-like glasses that allow wearers to 'see inside' objects | CES 2016 | The Guardian</a>
  • Debasmita Banerjee
    @debasmita-9A90wv • Jan 6, 2016
    Bike helmet customized by intel engineer using Intel Edison Board
    @abrakadabra • Jan 6, 2016
    X-ray vision is really come far! From sci-fi books to science labs, it doesnt feel far from reality now. I was reminded of a research work from University of Porto. Check: <a href="https://www.crazyengineers.com/threads/x-ray-vision-enables-drivers-to-see-through-the-trucks-to-overtake-them-safely.71263">X-ray vision enables drivers to see through the trucks to overtake them safely</a> This system also uses an Augmented Reality (AR) technique.
    Also,
    <a href="https://www.crazyengineers.com/threads/seeing-through-opaque-materials-possible-using-light-prove-scientists.78876">Seeing Through Opaque Materials Possible Using Light - Prove Scientists</a> They use ‘adaptive optics’.
    <a href="https://www.crazyengineers.com/threads/wi-vi-is-x-ray-vision-using-low-power-wi-fi-signals.68743">Wi-Vi Is X-Ray Vision Using Low Power Wi-Fi Signals</a> The device transmits a low-power wi-fi signal and then tracks its reflections to track moving objects, even if they are shielded by a wall.
    Amazing stuff.
  • Sahil Badani
    @sahil-badani-fLJODY • Jan 7, 2016
    It's a pity none of the above marvels have reached out for the world to see and use.
    I think in such cases, accessibility to the common man is imperative, otherwise a discovery is rendered as a discovery forever.
    Hope things change with the Intel-DAQRI product. That will sure be a revelation.
