Installing LED lighting at 10m height
Hi good day everyone, I'm about to install LED lighting in a factory( 10m height). But the problem is that i have limited spaces at the bottom due to lots of machineries. What would be a good suggestion aside from using scaffolding?
  • ChenKuang Yap
    @chenkuang-Kp0IVd • Nov 8, 2018
    the light will not be 10m above the machines but probably hung 2.5 meters. just use a lot of free wiring and swing it up on the roof then pull down
  • Adi Dzulkarnain
    @adi-z7PqfZ • Nov 8, 2018
    The exact distance to the roof is about 12m, and the distance of the light to the ground is about 8.7m. Will attach a picture tonight for refference
  • ChenKuang Yap
    you could winch the light cables up on hooks, stringing a line from one end of factory wall to the other, but there may be a slight curve if it's heavy
