  • information on file compression,
    poojasd
    poojasd
    @poojasd-QAgrYr
    Updated: Oct 21, 2024
    Views: 1.0K
    i need some help for file compression, actually we are having project in c, so may i get the algorithm of file compression in c....plz help...
    AdministratorAug 9, 2010
    poojasd
    Have you tried coding the algorithm on your own?If yes, share it with us so that we can help you rectify the errors or help you solve the problems you're facing.
  • Morningdot Hablu
    MemberAug 9, 2010
    Do you want to go with Lossless??
  • Leo
    MemberAug 9, 2010
    Hi Pooja, LZMA is one of the most used compression algorithm, goole for it and you will get its algorithm since every free compression tool provide this type of compression. Other compression algorithm that you can use is LZ77. And there is one algorithm which replaces every occurrence of similar bits and then remembering those places, by the way i don't remember its name. But you have wide choices just google it, compression algorithms are easy to find.Happy Computing.
