Improve on Clutch Life Span
Dear Ceans~!!!!
How to imporve the Clutch Life Span to avoid the transmission jammed in the middle of the journey to back home or long distance travel.
Should i replace the diaphagram Spring into Helix Spring and change the shape of the whole thing and also putting a bearing in the middle to allow the transmission shaft to turn even more efficiently?
If this helps, the stiffness of the spring and also the size would be consider on it.
What problem do clutch normally occur???
