@ramani-VR4O43 • Mar 25, 2013
Aziz, Reynold's number is just a number arising out of the conditions of the fluid flowing and not the other way. There is no such thing as harsh effects of Reynold's number. -
@zaveri-5TD6Sk • Mar 25, 2013
reynold's number is just a measure, and indicates whether the flow is laminar or turbulent. -
@ammar-aziz-7MLZYl • Apr 1, 2013
thankyou sir I agree! but there is still a question in my mind. As the reynolds number is the ratio of inertial and viscous force, while inertial force depends upom the mass and acceleration of flowing fluid and viscous force depends upon the density, than can we deduce that changing a particular parameter (like rate of change of velocity) is necessary to avoid a threshold value of reynolds number above which flow became turbulent in case of producing electricity from water turbine using jet of water?A.V.RamaniAziz, Reynold's number is just a number arising out of the conditions of the fluid flowing and not the other way. There is no such thing as harsh effects of Reynold's number.
if we can then it means that reynolds number is affecting the incoming jet of fluid...
please correct me if i am wrong! -
as i reply to sir biormani please explain me with some brief detail because i am still in confusionzaverireynold's number is just a measure, and indicates whether the flow is laminar or turbulent. -
@zaveri-5TD6Sk • Apr 4, 2013
Reynold's number is used to differentiate between turbulent flow and laminar flow.
however reynold's number is not the cause, but just an effect.
if the flow is turbulent , then reynold's number is greater 4000 or so. if laminar then it is below 2000.
so i hope this helps. reynolds number does not have any impact on anything, but it self gets affected due to the changing nature of the fluid flow -
@ammar-aziz-7MLZYl • Apr 4, 2013
good
