@sahithi-oJZaYj • Apr 5, 2010
Re: I'm getting 'registry editing has been diabled by admin' error, how to fix this e
Seems your system is totally infected. So, first Scan with best updated antivirus and with antimalwares, antispywares. -
@manish-r2Hoep • Apr 6, 2010
every folder has the exe,with the name of the folder name itself.😕
I think your system is infected by New Folder virus very tough to remove.
Have you scanned your computer before inserting pen drive?
Better to use quick heal anti-virus because among all the antivirus i had used until now it is the only one which can detect it and remove it -
@ms-cs-Ab8svl • Apr 6, 2010
I did not scanned,,..It is new folder virus only,I clicked that new folder.exe file unfortunately in hurry ..I will try quick heal antivirus,,, -
@optimystix-4yMPKC • Apr 6, 2010
yes ms_cs . its a virus which infected your system through a usb drive.
download and install autorun eater and panda usb vaccine.
both are small and free wares
autorun eater will detect any malicious autorun.inf file. and usb vaccine will vaccinate your usb drives by putting a non modifiable autorun.inf(safe one) in the drives. thus external malwares cannot write to it and thus it serves some amount of protection .
autorun eater will solve the registry, taskmanager and folder options disable problems easily. check the image below to fix it
no need to scan with anti viruses. most anti virus are not able to remove them. so it may turn out to be waste of time.
this should solve your problem.
if not then let us know ,. will tell you more 😀 -
thanks #-Link-Snipped-# : the technique you said worked... -
@optimystix-4yMPKC • Apr 7, 2010
your welcome 😀
viruses spreading through usb drives are more irritating (but less harmful) than the conventional pc viruses. and these days it's become difficult to do without usb drives. just a little care , like the ones mentioned above helps a lot.
i hope everyone makes it a point to secure their computers and usb drives 😀 -
@saurabh2486-Tr6NOC • Apr 7, 2010
his gives back access to REGEDIT :
maybe this will help -
@optimystix-4yMPKC • Apr 8, 2010
^^ it is way better and easier doing this using autorun eater.
