IBM Aptitude Questions
1. In 1978, a kg of paper was sold at Rs25/-. I f the paper rate
increases at 1.5% more than inflation rate which is of 6.5% a year
, then what wil be the cost of a kg of paper after 2 years?
a)29.12 (b) 29.72 (c) 30.12 (d) 32.65 (e) none of these
2. In A,B,C are having some marbles with each of them. A has giben
B and C the same number of marbles they already have to each of them.
then, B gave C and A the same no. of marbles they have, then C gave
A and B the same no. of marbles they have. At the
end A,B,and C have equal no. of marbles.
(i) If x,y,z are the marbles initially with A,B,C respectively.
then the no of marbles B have at the end
(a) 2(x-y-z) (b) 4(x-y-z)
(ii)If the total no. of marbles are 72, then the no. of marbles with A at the starting
a. 20 b. 30 c. 32
3. If a car starts from A towards B with some velocity due to some
problem in the engine after travelling 30km.If the car goes with
4/5 th of its actuval velocity the car reaches B 45min later to the
actual time. If the car engine fails ofter travelling
45km, the car reaches the destination B 36min late to the actual
time , what is the initial velocity of car and what is the distance between A and B in km
ans) 20 & 130.
4. A person has Rs 100/- in his pocket, he can as 25 pencils or 15books.
He kept 15% of the money for travelling expenses and purchased 5
pencils.So how many books he can purchase with the remaining money.
5. ten questions on analogies.
ex: hammer : carpenter ::
knife : butcher.
6. The values of shares A,B and C from january to june are as follows.
month A B C
JAN 30 60 80
FEB 35 65 85
MAR 45 75 65
APR 40 75 82
MAY 55 75 85
JUNE 50 75 80
i) During this period which share has undergone max fluctuation?
ii) In which month it is possible to buy B and C selling A?
iii) In which month the share values are very low?
iv) By purchasing one share of A and 4 each of B and C in the beginning
of the period , to get max profit when this shares should be sold?
v) ?
7. In a computer institute 9 languages can taught. The module is
of 6 months duration and only six languages each of one month can
be taught. In addition to that BASIC is always there and should be in first month itself
# word perfect is to be taught in the preceeding week of word star.
# FORTRAN can not be taught until COBAL is coarsed prior to that
# BINO, FIFO never be taught in single module
languages are BASIC, WORD STAR, WORD PERFECT, FORTRAN, COBAL, BINO, FIFO, LOTUS, C
i. Of the following which module is possible based on above conditions.
ii) If word star is in 3rd month , what could be in 6th month.
iii) If COBAL is in the 2nd month and BINO in 6th month are there
in addition to the above condition, FORTRAN will be in which month.
8. In a class , except 18 all are above 50 years. 15 are below 50
years of age. how many people are there
a) 30 b) 33 c) 36 d) none of these.
9. A square plot of some size , at four corners equal squares of
some size are cut and is formed as open box. If this open box carries
128ml of oil. What is the size of the plate i.e. side
a.17 b.14 c.13
10. In a square , all the mid points are joined. the inner square
is shaded. If the area of the square is A, what is the shaded area?
11. @(a,b)= (a+b)/2
/(a,b)= a.b
*(a,b)= ab , if a=1, b=2 find
i) /(a,(@(a,b),*(a,b)))
13. (x#y) = x+y-xy
(x*y) = (x+y)/2
i) (x#y)#(x*y) < (x#y), which of the below values of x, y will satisfy this equation
ii) (a*b)#(b*c)< (a#b)*(b*c) , what values of a,b,c satisfy the above.
. If you type in the command
nohup sort employees > list 2 > error out &
and log off ,the next time you log in . the output
will be
a). in a file called list and the error will de typed in
a file error out
b). there will be no file called list or error out
c). error will be logged in a file called list and o/p
will be in error out
d). you will not be allowed to log in
e). none of the above
The UNIX shell is....
a).does not come with the rest of the system
b).forms the interface between the user and the kernal
c) does not give any scope for programming
d) deos not allow calling one program from with in another
e) all of the above
.enum number { a=-1, b= 4,c,d,e}
what is the value of e ?
7,4,5,15,3
.The very first process created by the kernal that runs
till the kernal process is haltes is
a)init
b)getty
c)
d)
e)none
Result of the following program is
main()
int i=0;
for(i=0;i<20;i++)
switch(i)
case 0:i+=5;
case 1:i+=2;
case 5:i+=5;
default i+=4;
break;}
printf("%d,",i);
a)0,5,9,13,17
b)5,9,13,17
c)12,17,22
d)16,21
e)syntax error
What is the result
main()
char c=-64;
int i=-32
unsigned int u =-16;
if(c>i){
printf("pass1,");
if(c<u)
printf("pass2");
else
printf("Fail2");}
else
printf("Fail1);
if(i<u)
printf("pass2");
else
printf("Fail2")
a)Pass1,Pass2
b)Pass1,Fail2
c)Fail1,Pass2
d)Fail1,Fail2
e)none
2) In the process table entry for the kernel process, the process id value is
a) 0 b) 1 c) 2 d) 255 e) it does not have a process table entry
4) Which of the following API is used to hide a window
a) ShowWindow
b) EnableWindow
c) MoveWindow
d) SetWindowPlacement
e)None of the above
5) what will the following program do?
void main()
int i;
char a[]="String";
char *p="New Sring";
char *Temp;
Temp=a;
a=malloc(strlen(p) + 1);
strcpy(a,p); //Line no:9//
p = malloc(strlen(Temp) + 1);
strcpy(p,Temp);
printf("(%s, %s)",a,p);
free(p);
free(a);
} //Line no 15//
a) Swap contents of p & a and print😔New string, string)
b) Generate compilation error in line number 8
c) Generate compilation error in line number 5
d) Generate compilation error in line number 7
e) Generate compilation error in line number 1
6) In the following code segment what will be the result of the function,
value of x , value of y
unsigned int x=-1;
int y;
y = ~0;
if(x == y)
printf("same");
else
printf("not same");
a) same, MAXINT, -1
b) not same, MAXINT, -MAXINT
c) same , MAXUNIT, -1
d) same, MAXUNIT, MAXUNIT
e) not same, MAXINT, MAXUNIT
37) PATH = /bin : /usr : /yourhome
The file /bin/calender has the following line in it
cal 10 1997
The file /yourhome/calender has the following line in it
cal 5 1997
If the current directory is /yourhome and calender is executed
a) The calendar for May 1997 will be printed on screen
b) The calendar for Oct 1997 will be printed on screen
c) The calendar for the current month( whatever it is) will be printed
d) Nothing will get printed on screen
e) An error massage will be printed
38) what will be the result of the following program ?
char *gxxx()
static char xxx[1024];
return xxx;
main()
char *g="string";
strcpy(gxxx(),g);
g = gxxx();
strcpy(g,"oldstring");
printf("The string is : %s",gxxx());
a) The string is : string
b) The string is :Oldstring
c) Run time error/Core dump
d) Syntax error during compilation
e) None of these
39) What will be result of the following program?
void myalloc(char *x, int n)
x= (char *)malloc(n*sizeof(char));
memset(x,\0,n*sizeof(char));
main()
char *g="String";
myalloc(g,20);
strcpy(g,"Oldstring");
printf("The string is %s",g);
a) The string is : String
b) Run time error/Core dump
c) The string is : Oldstring
e) None of these
40) which of the following function is used to repaint a window immediately
a) Sendmessage(hWnd,WM_PAINt,......)
b) InvalidateRect(.......)
c) MoveWindow
d) WM_COPY
e) None
41) which function is the entry point for a DLL in MS Windows 3.1
a) main
b) Winmain
c) Dllmain
d) Libmain
e) None
42) The standard source for standard input , standard output and standard error is
a) the terminal
b) /dev/null
c) /usr/you/input, /usr/you/output/, /usr/you/error respectively
d) NOne
43) What will be the result of the following program?
main()
char p[]="String";
int x=0;
if(p=="String")
printf("Pass 1");
if(p[sizeof(p)-2]=='g')
printf("Pass 2");
else
printf("Fail 2");
else
printf("Fail 1");
printf("Pass 2");
else
printf("Fail 2");
a) Pass 1, Pass 2
b) Fail 1, Fail 2
c) Pass 1, Fail 2
d) Fail 1, Pass 2
e) syntax error during compilation
46) Which of the choices is true for the mentioned declaration ?
const char *p;
and
char * const p;
a) You can't change the character in both
b) First : You can't change the characterr &
Second : You can;t change the pointer
c) You can't change the pointer in both
d) First : You can't change the pointer &
Second : You can't chanage the character
e) None
49) The redirection operators > and >>
a) do the same function
b) differ : > overwrites, while >> appends
c) differ : > is used for input while >> is used for output
d) differ : > write to any file while >> write only to standard output
e) None of these
50) The command
grep first second third /usr/you/myfile
a) prints lines containing the words first, second or third from the file /usr/you/myfile
b) searches for lines containing the pattern first in the files
second, third, and /usr/you/myfile and prints them
c) searches the files /usr/you/myfiel and third for lines containing
the words first or second and prints them
d) replaces the word first with the word second in the files third and /usr/you/myfile
e) None of the above
