I have Java programming Related problems
sahilgandhi87
@sahilgandhi87-jf94Wy โ€ข Oct 22, 2024
when i run this program,it does nothing........it should produce sound but nothing.............What to do????
import javax.sound.midi.*;
class MiniMusicPlayer1
try
Sequencer sequencer = MidiSystem.getSequencer();
sequencer.open();
Sequence seq = new Sequence(Sequence.PPQ,1);
Track track = seq.createTrack();
for(int i=5;i<61;i=i+4)
track.add(makeEvent(144,1,i,100,i));
track.add(makeEvent(128,1,i,100,i+2));
sequencer.setSequence(seq);
sequencer.setTempoInBPM(220);
sequencer.start();
}catch(Exception e)
e.printStackTrace();
public static MidiEvent makeEvent(int comd,int chan,int one,int two,int tick)
MidiEvent event = null;
try
ShortMessage a = new ShortMessage();
a.setMessage(comd,chan,one,two);
event= new MidiEvent(a,tick);
}catch(Exception e)
return event;
  • CEMember
    @cemember-PlqlWH • Mar 8, 2009
    Hey sahilgandhi !
    What a superb work you have done ๐Ÿ˜€ Your program is perfectly working fine for me. It is making sound like someone is beating some musical instrument (I guess guitar or piano ๐Ÿ˜‰) very hardly.
    Check may be there is some problem in your computer system. You are not getting any compiler errors right? then just please wait for few seconds for listening the sound ๐Ÿ˜€
  • ms_cs
    @ms-cs-Ab8svl • Mar 8, 2009
    Only a single syntax error shown for me...
    Very superb program...If you have similar programs post it here.....
  • komputergeek
    @komputergeek-Yf5hJ4 • Mar 8, 2009
    @sahilgandhi87: Nice program.Working fine.
  • CEMember
    @cemember-PlqlWH • Mar 13, 2009
    ms_csOnly a single syntax error shown for me...
    Man, what syntax error it showed for you? ๐Ÿ˜• It was perfectly fine for me .
  • komputergeek
    @komputergeek-Yf5hJ4 • Mar 13, 2009
    Even I am not getting any syntax error.
  • ms_cs
    @ms-cs-Ab8svl • Mar 15, 2009
    CEMemberMan, what syntax error it showed for you? ๐Ÿ˜• It was perfectly fine for me .
    No ,,,While Copying the program I just missed some of the text
