How to use Javascript in PHP?
Arul Prakash
Arul Prakash
@arul-prakash-YCBAuT Oct 19, 2024
how can i use java scripts in PHP
    @abrakadabra Jul 5, 2012
    #-Link-Snipped-# What is it that you want to do? Please ask specific questions.
    Else this will help -
    <a href="https://www.itamer.com/using-php-and-javascript-together/278/" target="_blank" rel="noopener noreferrer">Using PHP and Javascript together – iTamer</a>
  • siraj.mussafirr
    siraj.mussafirr
    @sirajmussafirr-UMGx7y Jul 8, 2012
    Make clear the question. Do you want to load a php file and run javascript on the client browser ? Or do you wish to run javaScript at Server side?
  • Arul Prakash
    Arul Prakash
    @arul-prakash-YCBAuT Jul 9, 2012
  • Uday Bidkar
    Uday Bidkar
    @uday-bidkar-X1y63x Jul 13, 2012
    Whatever you write outside the php delimiters (most commonly used open/close delimiters are "<?php" and "?>") does not get processed by the PHP processor at server end and gets sent directly to the client as it is. So you can embed the javascript directly in your PHP file or can also point to external js file as you would do in plain HTML, outside the PHP delimiters
  • siraj.mussafirr
    siraj.mussafirr
    @sirajmussafirr-UMGx7y Jul 28, 2012
    Just print out the link for JS in the same way you do with HTML.
    This is a basic code snippet this would probably do:
    <?php
    echo "<script type='text/javascript' src='filename.js'/>";
  • Arul Prakash
    Arul Prakash
    @arul-prakash-YCBAuT Aug 15, 2012
    thank you dude....!
