@manish-r2Hoep • Nov 2, 2009
What kind of web services do you want in any application sookie???
@sookie-T06sFW • Nov 3, 2009
goyal420What kind of web services do you want in any application sookie???
Hey goyal420, thanks a lot for the reply. I already have some Web Service API ready and also have WSDL[Web Services Description Language]. I jus want to know what all steps one need to take for binding that wsdl in any application. I know one can call that Web services API method's in the application but what configurations one need to do for that.
In other way, I want to know the entire flow of working of Webservices
PS: Any kind of help will be appreciated in this regard . Thanks a lot ! -
@CrazyBoy • Nov 3, 2009
If you are interested in binding part then do the following:
WSDL โ <binding> element
- Tie the <portType> element to the protocol defined for the binding.
- Define the transport protocol and style (RPC or Document).
- For each operation of the <portType> each <message> needs to be detailed.
- For SOAP, the <soap:body> element needs to be defined, use (encoding or literal) and namespace.
- If using encoding, <soap:body> needs to specifiy encodingStyle.
Do let me know If you need anything specific.
-CB -
@CrazyBoy Thanks a lot that was really something informative response.
One question, if I have that part of binding in my WSDL document then how can I call the methods[or to be more precise called as 'operations' in Web Services world] in my applications web pages ? Is it possible to do anything like that ?
I am having two servers - First on which my current application runs[Can call it as Service Consumer] and Second is on which some other server is running providing some services [can be called as Service provider]. The Second server provides some services defined in a WSDL document. Now I want that WSDL to be found by First server [Service Consumer]
Can you give some ideas about it ? Rest of the part I will do. I just need some ideas about all this working concept. ๐
[EDIT]
One more thing, Do I need to create any proxy and stub sort of classes to call that service in my application or is it possible without using them also ?
Thanks a lot ! -
@sookie-T06sFW • Nov 5, 2009
Hi everyone
Thanks a lot for so much of your help. My problem is sort of solved. ๐
We can consume web services in an application by using #-Link-Snipped-#. I am simplifying the steps and writing them down here
STEP 1: Download separately[or can include them directly form Axis bin/lib folder if Axis is installed] and include following jar files in the CLASSPATH of your Client Class [Class which will consume services]
- axis.jar
- jaxrpc.jar
- saaj.jar
- commons-logging.jar
- commons-discovery.jar
- wsdl4j.jar
[More jars may be required to add depending on the WSDL you might be using.]
STEP 2: Download the WSDL file from Service Provider server's url For.eg. #-Link-Snipped-#
Add File with extension as .wsdl in your project. Let me name above WSDL file as StockQuote.wsdl
STEP 3: Now create stub classes using following command at run time. Go to appropriate structure of your project's folder and enter following command in Command prompt.
java -classpath D:\bin\axis-1_4\lib\axis.jar;D:\bin\axis-1_4\lib\jaxrpc.jar;D:\bin\axis-1_4\lib\saaj.jar;D:\bin\axis-1_4\lib\commons-logging.jar;D:\bin\axis-1_4\lib\commons-discovery.jar;D:\bin\axis-1_4\lib\wsdl4j.jar; org.apache.axis.wsdl.WSDL2Java StockQuote.wsdl
STEP 4: Now you can simply create Client class like following and use the operations specified in your WSDL. You can also pass paramters.
import org.apache.axis.client.Call; import org.apache.axis.client.Service; import javax.xml.namespace.QName; public class TestClient { public static void main(String [] args) { try { String endpoint ="https://www.webservicex.net/stockquote.asmx?WSDL"; Service service = new Service(); Call call = (Call) service.createCall(); call.setTargetEndpointAddress( new java.net.URL(endpoint) ); call.setOperationName(new QName("https://soapinterop.org/", echoString")); String ret = (String) call.invoke( new Object[] { "Hello!" } ); System.out.println("Sent 'Hello!', got '" + ret + "'"); } catch (Exception e) { System.err.println(e.toString()); } } }Finally, your work that you want to do using services is done. ๐
For basic flow of Web services , check #-Link-Snipped-#
PS: If any queries, Please ask- I may try to answer. -
@manish-r2Hoep • Jan 10, 2010
hey sookie can we consider this concept of web services similar to socket programming?I mean both are used for making connection and to retrieve the services..If i am right?If no can you please explain the difference?
