@thebigk • Feb 21, 2019
You haven't told us what are the problems you are facing. If your company does not offer you a role as a developer, you should look at other companies.ย
@mohit-n7d2qt • Feb 21, 2019
There is no future for anyone in your current organisation. You are going to look elsewhere for job opportunities anyway. However, when you are looking for a new job, it's better to go with your existing experience. It will be easier for you to find a manual testing job.ย
For Java developer job you can try your luck by applying to the companies that are recruiting Java developers.
@prasad-jdpPIg • Feb 22, 2019
Think of Selenium based testing, and writing automated test cases for Android via the Instrumentation path. It will open a plethora of possibilities for you. Focus on either of the approaches ย and learn to be good at that.
@thebigk • Feb 22, 2019
Right! As #-Link-Snipped-# said, it's better to opt for automation testing where you could make use of you Java programming knowledge.รย
