How to replace Hindi audio track with English in a video file?
I have a English short film with Hindi dubs. I want to replace it's audio file with the English audio track.
Is there a way to do it? If yes, please share the method to do that.
    @anoop-kumar-GDGRCn • Dec 15, 2013
    You need to download English audio source.
    I have used several video editor in which they show audio and video track separately . Just import English audio in current edit and remove Hindi one.
    I don't remember those software but most of them does it.
  • Raj A
    @raj-a-rU0vI3 • Dec 15, 2013
    I guess you need to check whether there is dual audio track available. If yes then you can easily switch from audio option.
    @abrakadabra • Dec 15, 2013
    How do we check that there is a dual audio track available or not?
    Ankita KatdareHow do we check that there is a dual audio track available or not?
    Open in VLC --> audio --> Select Track. But if you have multiple tracks then only it works.
    Otherwise you need to edit video to add/replace audio tracks.
  • Chinmay sharma
    @chinmay-sharma-3gsKma • Dec 16, 2013
    check in audio setting of any player such:-vlc,jetaudio etc......
    @sarathkumar-FEGRPw • Dec 16, 2013
    I had checked few websites but didn't found a easy solution .
    The audio track can be changed only if it is a multilingual dubbed movie.You should check the audio track before downloading.Replacing a audio and synchronization to the lip movement is a difficult and irritating process.That too finding a English audio file is frustrating.Better download it again with English track or simply use English subs.
  • Raj A
    @raj-a-rU0vI3 • Dec 16, 2013
    English sub-titles filles are readily available most of the times.. U may try those..
