How to Remove Write Protection on USB Pen Drive
Vikram S Bargah
@vikram-s-EgXevn โ€ข Oct 23, 2024
I have a SanDisk 16GB pendrive, when i'm trying to copy any content from USB to PC or viceversa its showing "Your Disk is Write Protected". Same is the case when I'm trying to format it .
Need your Suggestions.
  • HRG
    HRG
    @hrg-sm4qy1 • Jul 23, 2014
    try this ..
    Open the Windows Registry editor with the shortcut Windows-r, enter regedit into the form and press the return key on the keyboard.
    Navigate to the following Registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
    note that you may need to create the key StorageDevicePolicies if it does not exist. Select the key afterwards and right-click into the right window. Select New > Dword (32-bit) Value from the context menu and name the entry WriteProtect.
    Double-click the new entry afterwards and change the value from 0 to 1. A value of 1 disables writing to all connected USB devices. If you want to enable writing again you need to change the value of the key to 0.
  • Vikram S Bargah
    @vikram-s-EgXevn • Jul 29, 2014
    HRGtry this ..
    Tried those steps But it did'nt work out.
