How to make a hydraulic scissor platform ??
opedinho
@opedinho-eWxhy7 โ€ข Oct 22, 2024
project topic: DESIGN AND FABRICATION OF A PORTABLE WORK PLATFORM ELEVATED BY TWO HYDRAULIC CYLINDERS
( SCISSOR LINKAGES)
please gurus help me,i need to make it as early as possible to get an A+, and have few weeks left till presentation. any specs can be used or if available a manuscript/report. thanks
    @ramani-VR4O43 Oct 8, 2011
    opedinhoproject topic: DESIGN AND FABRICATION OF A PORTABLE WORK PLATFORM ELEVATED BY TWO HYDRAULIC CYLINDERS ( SCISSOR LINKAGES)
    You can see if these help:
    <a href="https://www.engineersedge.com/mechanics_machines/scissor-lift.htm" target="_blank" rel="nofollow noopener noreferrer">Scissor Lift Jack Equations and Loading Calculator</a>
  • rebellionofrebel
    @rebellionofrebel-k3kf5Z Nov 21, 2011
    With Hydraulic cylinders you can make a platform out of straight links !! normally Scissor links are used with Electric motors and you use a transmission system!!!!! Is there a specific advantage of using scissor platforms with hydraulic cylinders??? Do enlighten me !!!!
  • opedinho
    @opedinho-eWxhy7 Nov 22, 2011
    Yes, there is because when using hydraulic cylinders, it's dependency of power supply is eliminated,
    Long service life, Energy storage capability, High energy density.
    So, that's what i know about using the hydraulic system over electrical systems.
  • rebellionofrebel
    @rebellionofrebel-k3kf5Z Nov 23, 2011
    ok Wait.. even for normal electric drives, if the power falls the scissor platform does not simply roll donw!! it stays locked because the gear transmission box does not allow it to reverse power itself.. so dont worry on that part.. even for hydaulic systems u shall need electirc power for driving the pumps .. So in either case u will be using electric power .. Also u can have back up in both cases by Battery Banks!!!!! and if u platform is mounted on a vehicle , use the IC engine power of vehicle to drive ur pump in case of hydraulic system or drive motor in case of the electric system.
    The advantage of hydraulic system, is actually it helps u in lifting more weight and over more height!!!!!
