  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Nov 3, 2010
    There are several software available to create a bootable usb disk. One such is #-Link-Snipped-#
  • aj_onduty
    @aj-onduty-BvuwMK Nov 3, 2010
    gaurav.bhorkarThere are several software available to create a bootable usb disk. One such is #-Link-Snipped-#
    Gaurav, as I have not used a usb device as a bootable device, I need to ask you this. If a usb device is made bootable, then can it be changed back?
    Is that going to be a permanent change?
  • whiz.kid.aniket
    @whizkidaniket-5IiBCq Nov 3, 2010
    aj_ondutyGaurav, as I have not used a usb device as a bootable device, I need to ask you this. If a usb device is made bootable, then can it be changed back?
    @AJ! : you can make usb device back to normal. i.e change is not permanent!
  • ashishgupta652
    @ashishgupta652-nzpKVu Nov 4, 2010
    have u ever installed window through this software.,.?
    i mean to say ,.,does it works successfully,.,??
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Nov 5, 2010
    ashishgupta652have u ever installed window through this software.,.?
    Never installed though, but it works.
  • ashishgupta652
    @ashishgupta652-nzpKVu Nov 6, 2010
    i made the pd bootable but when i was installing window it showed some files were missing.,.,and i have installed the same window cd in other computers.
    can u tell me the another way to do this,.,??
    this soft doesnt work,.,
  • Manish Goyal
    @manish-r2Hoep Nov 6, 2010
    seach this forum
    you will get your answer
  • optimystix
    @optimystix-4yMPKC Nov 6, 2010
    soft works definitely
    there have been posts in this forum regarding the same earlier. search a little 😛
  • 4M4N
    @4m4n-jQmegc Nov 13, 2010
    Just create a file with extension ".ini" and name autorun.ini
    and edit it with notepad and write the following code into it
    [autorun]
    open=setup.exe
    now copy this file to pendrive, and also copy all the files from the folder where the setup of window is there(jst copy and paste as it is in the folder dont try to create new folders or etc) make sure that setup.exe file must be there whose name is given in the autorun file.
    Now reboot the system by inserting pendrive into,
    Hope this can help(i have tried it)
  • optimystix
    @optimystix-4yMPKC Nov 13, 2010
    what relation does autorun have with being bootable ?
  • 4M4N
    autorun makes execution of setup.exe automatically when ur system boot with pendrive already inserted and start the installation. without loading the previously installed OS.
  • themask
    @themask-kPDDPY Nov 25, 2010
    I've tried with my pd to boot Windows from It.
    Never succeeded. I doubt whether it can be done for sure?
    Anybody who have done successfully and using it, please tell us in a step by step to do how manner.
    Thanks in Advance
  • ashishgupta652
    @ashishgupta652-nzpKVu Jan 9, 2011
    no success till now,.
    can anyone tell me the exact procedure to make pd bootable to install xp.
    dere is no such other thread in this forum regarding this.
