how to hide a drive partition in computer ??
Here’s how:
1. First open Command Prompt (Start>Run>Type “cmd” without the quotes)
2. On the flushing cursor type “diskpart” (again without the quotes) Note: Wait for the Diskpart> and the flushing cursor to appear, usually it takes 5 seconds.
3. After the Diskpart> appears, type “list volume” (no quotes ok). It will then show all the drive in your computer including optical drives.
4. Select the drive you like to hide, for example using my system configuration, I want to hide drive d: then I’ll just type “select volume 3” (excluding the quotes). This varies depending on your system configuration.
5. After that, type “remove letter D” (again without the quotes). Then exit command prompt.
Your drive now is hidden, don’t worry its not been deleted of formatted, we just hide it. So if you want to see your drive again just follow the following.
To unhide the partition, repeat the steps 1-4 and on step 5 type “assign letter D” (ok again without the quote).
That’s all; your drive now is not hidden.
