@manish-r2Hoep • Sep 13, 2010
Sory didn't get you
what do you mean by java constraint program? -
@reya-SMihdC • Sep 13, 2010
The constraint programming approach is to search for the values of all the unknown variables in which the large no of constraints should be satisfied at the same time.JaCoP library provides
the constraint programming implemeted in java..And so it is called as java constraint program. -
have you set the class path?
what for class path here?do v have to mention the class path in netbeans?
Tell me exactly the error message it is showing ,if it is showing message like
package doesnot exist then I think there is problem related to classpath otherwise there may be some syntax related problem
Try this
import JaCop.*;
or import JaCop.core.*; -
@reya-SMihdC • Sep 14, 2010
i didnt get the error as package doesnt exists..
import JaCoP-3.0-RC1.*;
import java.util.*;
public class Main {
static Main m = new Main ();
public static void main (String[] args) {
FDstore store = new FDstore(); // define FD store
int size = 4;
// define FDVs
FDV[] v = new FDV[size];
for (int i=0; i<size; i++)
v = new FDV(store, "v"+i, 1, size);
// define constraints
store.impose( new XneqY(v[0], v[1]) );
store.impose( new XneqY(v[0], v[2]) );
store.impose( new XneqY(v[1], v[2]) );
store.impose( new XneqY(v[1], v[3]) );
store.impose( new XneqY(v[2], v[3]) );
// search for a solution and print results
ArrayList<FDV> list = new ArrayList<FDV>();
for(FDV var : v) list.add(var);
boolean result = Solver.searchOne(store, list, new SearchOne(),new IndomainMin(), new Delete());
if ( result )
System.out.println("Solution: " + list + "\n*** Yes");
else
System.out.println("*** No");
error message:
E:\Documents and Settings\SSN\My Documents\NetBeansProjects\JavaApplication15\src\javaapplication15\Main.java:8: '.' expected
E:\Documents and Settings\SSN\My Documents\NetBeansProjects\JavaApplication15\src\javaapplication15\Main.java:8: <identifier> expected
2 errors
E:\Documents and Settings\SSN\My Documents\NetBeansProjects\JavaApplication15\nbproject\build-impl.xml:413: The following error occurred while executing this line:
E:\Documents and Settings\SSN\My Documents\NetBeansProjects\JavaApplication15\nbproject\build-impl.xml:199: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 0 seconds)
where that dot should come in the first statement?i could not recognise.. -
@reya-SMihdC • Sep 15, 2010
can anyone help me?
@manish-r2Hoep • Sep 15, 2010
I don't have any idea about syntax and classes of JaCop library
So i picked a program from net and it is working fine on my PC
check whether the code that i given below is working fine or not
if not then the problem is with class path
import JaCoP.core.*; import JaCoP.constraints.*; import JaCoP.search.*; public class Main { static Main m = new Main (); public static void main (String[] args) { Store store = new Store(); // define FD store int size = 4; // define finite domain variables IntVar[] v = new IntVar[size]; for (int i=0; i<size; i++) v[i] = new IntVar(store, "v"+i, 1, size); // define constraints store.impose( new XneqY(v[0], v[1]) ); store.impose( new XneqY(v[0], v[2]) ); store.impose( new XneqY(v[1], v[2]) ); store.impose( new XneqY(v[1], v[3]) ); store.impose( new XneqY(v[2], v[3]) ); // search for a solution and print results Search<IntVar> search = new DepthFirstSearch<IntVar>(); SelectChoicePoint<IntVar> select = new InputOrderSelect<IntVar>(store, v, new IndomainMin<IntVar>()); boolean result = search.labeling(store, select); if ( result ) System.out.println("Solution: " + v[0]+", "+v[1] +", "+ v[2] +", "+v[3]); else System.out.println("*** No"); } } T -
working perfectly๐thank u so much dear๐
@reya-SMihdC • May 10, 2023
I have included the JaCoP library in netbeans..But still i get the error in the first line(import JaCoP -3.0-RC1.*; )of my prog.
