@thebigk • Aug 8, 2013
You haven't mentioned whether you want the copy the contents manually or use commands to do so. Copying manually is easy. Assuming that you're in Windows environment, you'll have to right-click on the command prompt Window and select 'Mark'. Then select the text you want to copy and then Rt.Click -> Copy.
I think you already know this. Please clarify your requirements. -
@nayan-Dhpt4N • Aug 8, 2013
After any command you execute, add this ">filename.txt". this will add the output of your command into thisfile. For ex:
tracert <a href="https://www.crazyengineers.com">CrazyEngineers</a> > trace.txt
This command will make a file trace.txt in your current working directory and copy all the output there instead of showing it on the screen. -
@vishal-pysGmK • Aug 8, 2013
I'm not being answered to what I've asked
Leaving the manual stuff behind, I want to go for a programmatic way.
This command will make a file trace.txt in your current working directory and copy all the output there instead of showing it on the screen.โyes, this works.. It is called re-directing and it works only with commands.. my question is not this. If something is already being displayed, that content should be moved to a text file. I think in linux we have script command to perform this kind of operation.. what about windows?
@rukawa-Y0pUkC • Aug 8, 2013
Vishal0203I think in linux we have script command to perform this kind of operation.. what about windows?
What's the way to do this kind of operation in linux? -
@vishal-pysGmK • Aug 9, 2013
rukawaWhat's the way to do this kind of operation in linux?
Script i think.. never used linux though.. got this suggestion from someone -
@sookie-T06sFW • Aug 27, 2013
Have you tried doskey /history >> commands.log ?
@kenjackson-mBf7HF • Aug 27, 2013
Most things that you can do in Linux, including <a href="https://en.wikipedia.org/wiki/Script_(Unix)" target="_blank" rel="nofollow noopener noreferrer">Script (Unix)</a>, you can do in the <a href="https://cygwin.com/" target="_blank" rel="nofollow noopener noreferrer">Cygwin</a> environment in Windows. That is, download setup-x86.exe or setup-x86_64.exe from Cygwin and execute it to install a Linux-like tools for Windows. I couldn't use Windows without it.
