  • How the protection of transformer can be done using SCADA
    Mr.Don
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    Generally,in brief my lecturer told that SCADA is computer based process of supervisory control and data acquisition and when the fault is generated a frequency will be generated at the fault station(modulation) which matches(will the same) frequency in the control frequency and when the control room receives the signal it rectifies the fault at that place..Is this about the operation on protection of transformer or anything else about this..CEans could you please elaborate this issue..and clear my doubts on SCADA for transformer protection.
  • manoj_2all
    MemberNov 3, 2010
    dileep k
    SCADA cannot be directly connected to the transformer: it is just an overview of your system it needs an another system like PLC which can be connected, to the transformer system.
  • d_vipul
    MemberNov 4, 2010
    SCADA is just a viewer it does not protect any equipment directly.....
    You are right manoj........
    Regards,
    VIPUL
  • Arp
    MemberJan 13, 2011
    vipul is right scada is the only thing which show u all readings in a control room and from where u can change where settings only... u need to install protection devices for transformer in its switchgear panel
    this is by the best of my knowledge
