How does aircraft gas turbine works?
Hi all
Would like to know about how does aircraft gas turbine engine work.
I have watch you tube video and google on it. But seem to have some doubt.
From my understanding, air is being suck into the compressor, which increase the pressure of air. Some percentage of compress air will pass through the combustion chamber and some will get into the combustion chamber. There will have a fire to ignite the compress air to let it increase in temperature. where lead to the turbine to rotate and also rotate the compressor fan blade. and the rest of air is use as thrust to drive the aircraft to be in the air.
My question is: 1) why does temperature increase help to increase the thrust of the aircraft. 2) what is the purpose of fuel in aircraft? is it constantly supply to maintain the fire in the combustion chamber?
