@rahul69-97fAOs • Oct 13, 2012
Well, I am not sure but I think signal propagation is bidirectional in an internet connection.
@rajay-VnEnTx • Oct 14, 2012
Hello "SheldonCooper", the broadband connection is named broadband because it has a "broad" bandwidth and hence more data can be transmitted. Many signals can propagate if there is more bandwidth. So, it isn't unidirectional. Basically, the digital data is sent over high frequencies over the same telephone line which then gets filtered out at the customer end. As the telephone data is carried over lower frequencies & the broadband over high, it's an easy task.
So I think this should answer your question. -
@sheldoncooper-KRWqFp • Oct 16, 2012
RãjayHello "SheldonCooper", the broadband connection is named broadband because it has a "broad" bandwidth and hence more data can be transmitted. Many signals can propagate if there is more bandwidth. So, it isn't unidirectional. Basically, the digital data is sent over high frequencies over the same telephone line which then gets filtered out at the customer end. As the telephone data is carried over lower frequencies & the broadband over high, it's an easy task.
So I think this should answer your question.Explain me the meaning of the following sentence from CN notes from IIT kgp.
"In broadband signaling, signal propagates only in one direction, in contrast to propagation in both directions in baseband signaling. Broadband cabling uses either dual-cable scheme or single-cable scheme with a headend to facilitate flow of signal in one direction" . The sentence is in the point "Baseband coaxial cable" point as well as "broadband coaxial cable" point.Now tell me what is dual cable? The one we use in telephone has 2 threads (+,-)so it is single cable right? Then dual cable means 4 threads right? And what is headend and how it works?
I checked in reference books and internet but haven't got my answer still. No one is denying it but no one is telling it clearly. -
@jeffrey-xA7lUP • Oct 16, 2012
So I think this should answer your question.My friend if you are to send digital data you can't use serial data transmission tactics as they are really losy and cause a lot of distortion to the siganl message
So we generally go for parallel transmission as then only recovery of data is easier in the reception end
Am I not right otherwise do correct me
And the question in concern I think a Voltage varied pulse form of signal is sent in through the cable having the two cores the pulse are then demodulated to get the required Digital ip which is understood by the computer -
@sheldoncooper-KRWqFp • Oct 17, 2012
Dear #-Link-Snipped-#. Your answer is 80% gone above my head. Can you explain in more detail without too much electronics jargon so that it will come in my band of understanding?😀
@jeffrey-xA7lUP • Oct 17, 2012
Sorry beating to much about the bush
Here is my point in precise
To represent a single dot in digital format minimum of 8 bits are required in real practise am I not right
Next this has to be transmitted right
If the data is sent serially there is higher chance of data lagging to occur due to environmental factors ( only 1 bit is sent at a time in serial connection )
This can prevent the continuous flow of data to the receiver causing errors so we must send the data parallelly causing a need for more transmitters and receivers
So generally this is not preferred for longer distance but only for shorter distance
This hinders digital transmission to a wider range causing a need for analog data transmission which is sent through the the Live wire in the telephone whereas the other wire is a neutral return path to the station closing the circuit. -
@sheldoncooper-KRWqFp • Oct 22, 2012
jeffrey samuelSorry beating to much about the bush
This hinders digital transmission to a wider range causing a need for analog data transmission which is sent through the the Live wire in the telephone whereas the other wire is a neutral return path to the station closing the circuit.Ok. This cleared point of Serial Transmission and Parallel Transmission and why parallel is used here. Now tell me how a single wire can support full duplex mode at a same time? Consider data is flowing from A to B through the telephone line mentioned above. Now my point is how the same line carry data from B to A at the same time? I am not keen in basics so please explain me with lowest level as you explained in your above reply.
@jeffrey-xA7lUP • Oct 23, 2012
simple reason friend 1 spot is represented by more than 16 bits and so we need parallel transmission
