  • Gurjap
    @gurjap-blPmg9 • Feb 9, 2012
    It's like this: the more fuel you spray into the engine, the more power it will develop. Meaning, of course, that it will go faster. So when you press/twist the accelerator, it causes the fuel supply to the engine to increase, causing....well, acceleration. Note that his is a very brief explanation, so I've left some things out.
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Feb 9, 2012
    For most cars, the accelerator pedal is connected to a throttle body which opens up depending on how much the pedal is pushed. The throttle allows air to enter the combustion chamber where a series of controlled explosions drive the pistons transferring power to the transmission and then to axles (overly simplified). Some cars have a throttle position sensor that will control fuel input based on the position of the throttle. Some have a mass air sensor that measures the amount of air entering and adjusts fuel to a preset ratio. Some newer cars do not connect the accelerator to the throttle directly (drive by wire). The ECU determines the throttle position based on the pedal position.
    Check this out too:
    <a href="https://auto.howstuffworks.com/electric-car2.htm" target="_blank" rel="nofollow noopener noreferrer">Inside an Electric Car | HowStuffWorks</a>
  • Dancer_Engineer
    @dancer-engineer-EJ8rGI • Feb 11, 2012
    Praveen-KumarFor most cars, the accelerator pedal is connected to a throttle body which opens up depending on how much the pedal is pushed. The throttle allows air to enter the combustion chamber where a series of controlled explosions drive the pistons transferring power to the transmission and then to axles (overly simplified). Some cars have a throttle position sensor that will control fuel input based on the position of the throttle. Some have a mass air sensor that measures the amount of air entering and adjusts fuel to a preset ratio. Some newer cars do not connect the accelerator to the throttle directly (drive by wire). The ECU determines the throttle position based on the pedal position.
    Check this out too:
    Looks like you forgot to mention the #-Link-Snipped-#. ๐Ÿ˜€
    @praveenkumar-66Ze92 • Feb 11, 2012
    Dancer_EngineerLooks like you forgot to mention the #-Link-Snipped-#. ๐Ÿ˜€
    Can Y! A can be taken as a source?
  • Dancer_Engineer
    Praveen-KumarCan Y! A can be taken as a source?
    If you are copying pasting then you must mention the source / link.
    @praveenkumar-66Ze92 • Feb 12, 2012
    Okay...
    [โ€‹IMG]
