Here is an easy one.
zaveri
@zaveri-5TD6Sk โ€ข Oct 26, 2024
Once a circus artiste was on his way to his hometown, and he had to cross a bridge. the bridge was nearly old, and weather-beaten and it posed the danger of collapsing if overloaded. the bridge could not take loads more than 60 kgs. now the artiste alone was 59 kg, and he had with him three balls, each weighing half a kg, the sum total of all the weights which exceeds the capacity of the bridge. now how did this guy make it across the bridge in one piece with all his belongings intact ?
  • nareshkumar6539
    @nareshkumar6539-BKuVbx • Aug 16, 2012
    zaveriOnce a circus artiste was on his way to his hometown, and he had to cross a bridge. the bridge was nearly old, and weather-beaten and it posed the danger of collapsing if overloaded. the bridge could not take loads more than 60 kgs. now the artiste alone was 59 kg, and he had with him three balls, each weighing half a kg, the sum total of all the weights which exceeds the capacity of the bridge. now how did this guy make it across the bridge in one piece with all his belongings intact ?
    Artist alone and 2 balls together is 60kg,the remaining one ball is in air.he walk through the bridge by playing with balls like every time 2 balls in his hands remaining one ball in the air.if he do like this total weight is 60 kg there is no overload and he crosses the bridge.
  • Sean720
    @sean720-xqL903 • Aug 18, 2012
    nareshkumar6539Artist alone and 2 balls together is 60kg,the remaining one ball is in air.he walk through the bridge by playing with balls like every time 2 balls in his hands remaining one ball in the air.if he do like this total weight is 60 kg there is no overload and he crosses the bridge.
    so he juggles them?
  • zaveri
    @zaveri-5TD6Sk • Aug 18, 2012
    Sean720so he juggles them?
    Yes of course.
    @ramani-VR4O43 • Aug 19, 2012
    That is OK as a puzzle. However,it would not pass as an engineering solution. The ball that is in the air has to be thrown up to get into the air. This causes a downward thrust which adds to the weight, which will exceed the safe bearing load and the bridge will collapse.
  • Reya
    @reya-SMihdC • Aug 19, 2012
    bioramaniThat is OK as a puzzle. However,it would not pass as an engineering solution. The ball that is in the air has to be thrown up to get into the air. This causes a downward thrust which adds to the weight, which will exceed the safe bearing load and the bridge will collapse.
    Whoa! That's an Engineer ๐Ÿ˜€ I thought, throwing the ball to the other side of the bridge before he could cross the bridge ๐Ÿ˜”
    ReyaWhoa! That's an Engineer ๐Ÿ˜€ I thought, throwing the ball to the other side of the bridge
    That is an ingeneur! Exactly what should be done.
  • zaveri
    @zaveri-5TD6Sk • Aug 19, 2012
    the reaction force of course ! But overall the problem itself is an impractical one. because first a person has to either well talented or well trained to juggle and walk at the same time.
