Help with 6 axis
Clue144
@clue144-Zp32Yg โ€ข Oct 22, 2024
Hello i need help to get this working if its possible, will try explain what i have come to.
I have 2 dc motors that I want to control six different axes,
if motor 1 spins right and motor 2 spins left then the first axle will rotate.
if motor 1 spins left and motor 2 spins right then the second axle will rotate.
if motor 1 is stoped and motor 2 spins right then the third axle will rotate.
if motor 1 is stoped and motor 2 spins left then the fourth axle will rotate.
if motor 1 spins left and motor 2 is stoped then the fifth axle will rotate.
if motor 1 spins right and motor 2 is stoped then the sixth axle will rotate.
Ok i hope someone understand this, this would work if i know how to build it, I have a couple of gears but its seems impossible.
Can anyone help me, show me or explain how exactly i can do or give me another teory to make this ?
  • Ashraf HZ
    @Ash • Jan 16, 2009
    Interesting! ๐Ÿ˜› I'll move this to the Mechanical Section.
    By 6 axis you only mean rotation among the x-y-z, and another 3 planes?
    Usually, the term "6 axis" would mean rotational AND lateral motion on the x-y-z axes.
  • Clue144
    Clue144 OP
    @clue144-Zp32Yg • Jan 16, 2009
    maybe i ment wrong, i have made a quick image
    [โ€‹IMG]
    those thick black lines are round tubes to spin ... my 6 axle
    and i whant to spin them one at the time with 2 dc motor if its possible
  • Ashraf HZ
    @Ash • Jan 16, 2009
    Yes, it is possible, but you'll need to use some complex gear configurations. Lets wait for the mechanical or robotic CEans to comment.
