Help needed for parallel port interfacing using matlab
silverscorpion
@silverscorpion-iJKtdQ • Oct 26, 2024
hi guys,
I'm making a robot and i want it to be controlled by the computer. But the robot should be capable of travelling a long distance,(probably some ten to twenty feet). So using a wired robot doesn't seem to be a good choice. I wanna interface a rf remote control to the parallel port to control the bot. Is it possible? Can anyone tell me how to do it using matlab? If not, someother software like vc++ is also ok...
Thanks.
  • raknahs2
    @raknahs2-CtoW8u • Jan 11, 2008
    Hi Dude,
    controlling parallel port through MATLAB is quite simple.
    Check below lines of MATLAB code which I am using in my project.
    dio = digitalio('parallel','LPT1')
    --> create an object
    data1 = addline(dio,0:7,0,'out') %Pin 2-9
    data2 = addline(dio,0,2,'out') %Pin 1
    data3 = addline(dio,1,2,'out') %Pin 14
    --> to configure parallel port line
    Following command will output "0" to data1 of parallel port
    putvalue(data1,0)
    Don't hesitate to ask me if you have any queries.
  • jowie_510
    @jowie-510-DqkRT7 • Jan 12, 2008
    hi bro..
    I also making a robot and i still confiuse about that (the discussion above)..but i think my question is still in this scope..
    is it the connection between computer and the robot is without wire??..
    Hope anyone can explain detail...
    thanks..
  • raknahs2
    @raknahs2-CtoW8u • Jan 13, 2008
    No. MATLAB code given above is to interface a peripheral (a device) via parallel port with the PC.
  • jowie_510
    @jowie-510-DqkRT7 • Jan 14, 2008
    ok.. thanks for your explanation..
  • Zentill.now
    @zentillnow-wMSynw • Feb 15, 2008
    This thread was of great use for me thank u........
  • Reaver
    @reaver-TipuLt • Mar 30, 2008
    Hye i want to control a lift (I hav made my own mechanical structure).
    Just give me a example of how to turn on/off 4-5 leds using parallel port through matlab plzzzzzzzzzzz
  • gtugac
    @gtugac-EfW3cT • May 22, 2008
    hi everyone
    i also have this project where i only have to control 5 leds by MATLAB...
    and i have to use my laptop to do it.
    i have found some information about using serial-parallel ports and recently have a premade PIC circuit. but still i have so little time that i need your advices emergently...
    thanks
  • Himanshutime
    @himanshutime-lwGhbp • Jun 2, 2008
    this is done by using embeded programing and using infrared or radio wave signals and made a device to genrate perticular signals conect on 25 pin parlel port by using rs232 wier, but i want to conform you that is your robot is able to move on stayers by themself if yes please tel me how?
    by
  • Himanshutime
    this is done by using embeded programing in c langwage and using infrared or radio wave signals and made a device to genrate perticular signals conect on 25 pin parlel port by using rs232 wier, but i want to conform you that is your robot is able to move on stayers by themself if yes please tel me how?
    by
  • heloitsadi
    @heloitsadi-n7qUza • Sep 4, 2009
    Check this out guys..
    <advertisement link removed>
  • coolbreeze
    @coolbreeze-QTEeYt • Jan 25, 2010
    Ms thesis
    This is code for parallel interference cancelltion in ds cdma using matrix algebraic approach.
    Please check the code and let me know if iam doin any mistake . Also I need to apply slow and fast rayleigh fading in this model.
    The rcd signal is R = SAB + N
    where R,S,A,B are matrices
    The matlab code is given below :
    close all
    clear all;
    clc;
    warning off all
    K = 27; %No. of users
    Navg = 1e3; %No. of repititions
    snr = 5:1:25; %SNR RANGE
    Sv = (10.^(-snr/10)); %Noise variance in different SNR
    A = eye(K); %input power
    %Get signature sequences
    load GS31;
    S = GS31(1:K,;
    S= S';
    Lc = length(S😀,1));
    Sn= S./sqrt(Lc); %Normalize energy of signature waveforms
    R = Sn'*Sn; % Calculate correlation matrix
    corr=(R-eye(size(R)));
    h = waitbar(0,'WAIT...');
    for t = 1:Navg
    waitbar(t/Navg);
    for j = 1:length(snr)
    noise =(Sv(j))^.5*randn(Lc,1);
    b=2*(randint(K,1)-0.5);
    BT=Sn*A*b;
    r=awgn(BT,snr(j));
    % r=BT+noise;
    y = Sn'*r;
    ysdec = inv(R)*Sn'*r;
    YMF = sign(y);
    YDEC= sign(ysdec);
    novector(1:K) = Sv(j);
    sigma2= diag(novector);
    t1=R+sigma2;
    ysmmse = (inv ( t1 ))* y;
    YMMSE= sign(ysmmse);
    %%CPIC
    yinit=zeros(K,1);
    ypic1= (Sn'*r) + yinit ;
    YPIC1 = sign(ypic1);
    yinit2=ypic1;
    ypic2=(Sn'*r) - ( corr*A*yinit2 );
    YPIC2 = sign(ypic2);
    yinit3=ypic2;
    ypic3=(Sn'*r) - ( corr*A*yinit3 );
    YPIC3 = sign(ypic3);
    yinit4= ypic3;
    ypic4=(Sn'*r) - ( corr*A*yinit4 );
    YPIC4 = sign(ypic4);
    yinit5= ypic4;
    ypic5=(Sn'*r) - ( corr*A*yinit5 );
    YPIC5 = sign(ypic5);
    yinit6=ypic5;
    ypic6=(Sn'*r) - ( corr*A*yinit6 );
    YPIC6 = sign(ypic6);
    yinit7=ypic6;
    ypic7=(Sn'*r) - ( corr*A*yinit7 );
    YPIC7 = sign(ypic7);
    yinit8=ypic7;
    ypic8=(Sn'*r) - ( corr*A*yinit8 );
    YPIC8 = sign(ypic8);
    ERMF(j)= length(find (YMF ~= b))/K;
    ERDEC(j)= length(find (YDEC ~= b))/K;
    ERMMSE(j)= length(find (YMMSE ~= b))/K;
    ERPIC1(j)= length(find (YPIC1 ~= b))/K;
    ERPIC2(j)= length(find (YPIC2 ~= b))/K;
    ERPIC3(j)= length(find (YPIC3 ~= b))/K;
    ERPIC4(j)= length(find (YPIC4 ~= b))/K;
    ERPIC5(j)= length(find (YPIC5 ~= b))/K;
    ERPIC6(j)= length(find (YPIC6 ~= b))/K;
    ERPIC7(j)= length(find (YPIC7 ~= b))/K;
    ERPIC8(j)= length(find (YPIC8 ~= b))/K;
    end
    EERMF(t,=ERMF;
    EERDEC(t,=ERDEC;
    EERMMSE(t,=ERMMSE;
    EERPIC1(t,=ERPIC1;
    EERPIC2(t,=ERPIC2;
    EERPIC3(t,=ERPIC3;
    EERPIC4(t,=ERPIC4;
    EERPIC5(t,=ERPIC5;
    EERPIC6(t,=ERPIC6;
    EERPIC7(t,=ERPIC7;
    EERPIC8(t,=ERPIC8;
    end
    BERMF = smooth(mean(EERMF,1));
    BERDEC = smooth(mean(EERDEC,1));
    BERMMSE = smooth(mean(EERMMSE,1));
    BERPIC1 = smooth(mean(EERPIC1,1));
    BERPIC2 = smooth(mean(EERPIC2,1));
    BERPIC3 = smooth(mean(EERPIC3,1));
    BERPIC4 = smooth(mean(EERPIC4,1));
    BERPIC5 = smooth(mean(EERPIC5,1));
    BERPIC6 = smooth(mean(EERPIC6,1));
    BERPIC7 = smooth(mean(EERPIC7,1));
    BERPIC8 = smooth(mean(EERPIC8,1));
    semilogy(snr,BERMF,'k*-',snr,BERPIC1,'m^-',snr,BERPIC2,'rs-',snr,BERPIC3,'yo-',snr,BERPIC4,'k<-',snr,BERPIC5,'c^-',snr,BERPIC6,'y^-',snr,BERPIC7,'r>-',snr,BERPIC8,'bs-',snr,BERDEC,'g*-',snr,BERMMSE,'go-');
    grid on
    xlabel('SNR')
    ylabel('Average BER')
    legend('MF','Stage1','Stage2','Stage3','Stage4','Stage5','Stage6','Stage7','Stage8','DECOR','MMSE')
    title('BER vs SNR--Conventional PIC-25 Users -AWGN Channel')
    close(h)
    Added after 1 minutes:
    Dear all,
    The : ) got replaced by a smiley.
    I need urgent reply regarding fading
    thanks in advance
  • Ahsanmohyuddin
    @ahsanmohyuddin-wmXwbv • Dec 2, 2010
    raknahs2Hi Dude,
    putvalue(data1,0)
    Dear
    I am working on an idea, i want to control the direction of DC motor(clockwise or anticlockwise)
    using GUI and parallel port. I have made a GUI on MATLAB but don't know how to program its .m file
    GUI figure is attached.
    [​IMG]
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    I have added two options
    i- clockwise
    ii-anticlockwise
    I redefine the problem
    " select any one of the direction and press 'ok'.
    if selected ' clockwise' send 0 to pin2 of parallel port
    if selected ' anticlockwise' send 1 to pin2 of parallel port
    I am waiting for your reply
    @thebigk • Dec 2, 2010
    Please upload your images to imageshack.com and then enter full URL of the image (ending in file extension) in the [​IMG] button on the post editor.
  • Ahsanmohyuddin
    The_Big_KPlease upload your images to imageshack.com and then enter full URL of the image (ending in file extension) in the [​IMG] button on the post editor.
    this site is not allowed in my area.... Is image i have added is not visible?
