Help Me in my Robotics Project
adil.eshack
@adileshack-t30OC5 โ€ข Oct 25, 2024
Greeting Fellow Crazy Engineers,
Myself Adil from Kerala,Indial.Final year mechanical engineering student. Myself and 4 others have ventured to do a robotics project
The concept is simple fix a wireless camera to the robot which gives a live feed to a java program and to control the robot movement using the keyboard.
We intend to make a robot around 760mm high and 40mm in dia.Its in the form of a cylinder.It weighs around 3 kg. its a three wheeled robot wid seperate drives to the back two wheels and a free to rotate front wheel.Rotation of robot is controlled by rotating the back two wheels at different speeds
THE PROBLEM : could u please suggest what type of motor to use. We used small DC motors in our small projects. But given its weight wat motor i should use. Also please suggest a way in which i can connect the motor to the wheels so that load is less on motor shaft.
Also how do i calculate the torque required as in for the weight of my robot
  • adil.eshack
    @adileshack-t30OC5 • Mar 12, 2008
  • adil.eshack
  • Ashraf HZ
    @Ash • Mar 12, 2008
    Eek, you've posted everywhere! I've moved this to Project Ideas forum, since we have many robotic related discussions here. Please wait for other CEans to reply ๐Ÿ˜€
  • ranvir1986
    @ranvir1986-P2BWoj • Mar 30, 2008
    the torque required also depends upon the diameter of the wheels. Smaller wheels require lesser motive force. Do connect the motor straight to the wheels. Use a gear system. The motor used for Vipers in cars is a very powerful yet compact motor. U can also get servo motors that give you as much as 2 kg-m of torque and are very light and run on 6v circuit.
  • akkumon
    @akkumon-UtRUcW • Sep 23, 2009
    I consider you to use stepper motor because using it you can precisly control the movement.
  • pranayagarwal
    @pranayagarwal-ETn3QR • Dec 18, 2009
    helloo..may u help me in leading forward for this project (matlab controlled robot used for robo soccer). i have basic idea of matlab ,image processing .
  • sasha.pinoyako
    @sashapinoyako-C62wgX • Jul 19, 2010
    heeyy. guys. sasha here. from Philippines. a junior student. can you guys give me some ideas regarding our investigatory project in physical science? our group thinks that robotics is a good one but we dont have any idea about it honestly. thanks๐Ÿ˜€
