@arunchary-VtqB3c • Mar 24, 2013
i think no need to use A/D converter while interfacing Reed switch or sensor to microcontroller.below shows a simple reed switch interfacing.
<a href="https://kitsnspares.com/admin/pdffiles/Speedometer%20Cum%20Odometer.pdf" target="_blank" rel="nofollow noopener noreferrer">PDF</a> -
@thebigk • Mar 24, 2013
I'm curious to know what all functions and features would a GSM based home automation system can have? Also, I haven't heard of CDMA based home automation system - does that even make sense? ๐
@anand-tamariya-DnfjEX • Mar 24, 2013
Ideally, one would want to separate input(GSM, CDMA, bluetooth, wifi, sensors etc.) and output (controlling switch) for home automation. The modular design will allow you to mix-and-match various scenes. e.g. read SMS and perform operation, switch off lights after you have left home, switch on AC if the temp. goes above certain threshold etc. I've one working for my home .
I'm curious though - why would you want to use A/D with reed switch :-?
