GPS Data Logger
abhinav.gamer
@abhinavgamer-CgCwJ4 โ€ข Oct 25, 2024
Hello CEans,
I am making a GPS Data Logger that would store raw GPS signals from GN3S sampler on to a SD card. I am thinking of using a PIC. The only problem I have in understanding is how do I convert the differential data from USB to store on the SD card? I am attaching the circuit diagram which I have conceived till now.
[โ€‹IMG]
Help appreciated.
Thank you.
    @harshad-ukH5ww • May 2, 2012
    I am not sure in this project where you are going to use USB?
    You need to get the Raw data from GPS Module and save it to SD Card right?
  • abhinav.gamer
    @abhinavgamer-CgCwJ4 • May 2, 2012
    The gps receiver has a usb interface to connect it and retrieve data.
    I want to connect it to the PIC and save the data on the SD card without implementing any file system.
    abhinav.gamerThe gps receiver has a usb interface to connect it and retrieve data.
    I saw GPS devices which supports SPI as well UART. But in your case as it is USB your Controller should support USB host. if you have not purchased GPS module yet then you can use another GPS modules.
    I saw some GPS with SPI or UART interface. If you have not purchased Module yet you can change your Module with one which gives your direct data via UART then your firmware development time will become easy.
  • abhinav.gamer
    @abhinavgamer-CgCwJ4 • May 3, 2012
    Unfortunately I have the GPS module. So I have to get the data from the USB. Any help?
    @harshad-ukH5ww • May 3, 2012
    Let me check your PIC MCU supports USB or not.
    Well PIC16F819 is not supporting USB.
    I have one idea not sure whether it will work or not but you can try it.
    There is FTDI and PL2303 USB to Serial Converter available take any and Connect your GPS with that Chip and PL2303 can convert USB signal to UART TTL logic that you can use to interface with PIC16F819.
  • AT-OK
    @at-ok-E0bCzz • May 3, 2012
    Agree with godfather..but better buy a GPS modual with Serial interface..as it will be cheaper and more reliable to you.
    FTDI & PL2303 modual hangs sometimes at Power ON,so better you do't use for this application.
    AT-OKAgree with godfather..but better buy a GPS modual with Serial interface..as it will be cheaper and more reliable to you.
    Agree with #-Link-Snipped-# Suggestion. It is better to buy New GPS Module instead of changing PIC MCU.
  • abhinav.gamer
    I have the GPS module. I better change the PIC MCU. Any suggestion on the PIC which will support USB? The main doubt I have is can the differential signal from USB be stored on a MMC?
    abhinav.gamerI have the GPS module. I better change the PIC MCU. Any suggestion on the PIC which will support USB? The main doubt I have is can the differential signal from USB be stored on a MMC?
    I will let you know PIC series supporting USB. and Regarding storing on MMC once you have data in MCU Buffer you can easily transfer same to MMC.
  • abhinav.gamer
    I was hoping of using PIC16C745 which is a 8-bit MCU.
    Will a 8-bit MCU suffice for such an application or should I go for the 16-bit version?
    @harshad-ukH5ww • May 4, 2012
    Go with PIC18F2550 It supports USB. ๐Ÿ‘
