Gizmo Board: AMD APU-Based Embedded System Launched By GizmoSphere
Here at VoiCE we are fans of #-Link-Snipped-# and its #-Link-Snipped-#. This $25 (1,345 INR) priced computer has been a favorite of enthusiasts worldwide. For all those embedded systems inventors and hobbyists who want a more powerful device to play with GizmoSphere has launched Gizmo Board which is powered by AMD Embedded G-Series Accelerated Processing Unit (APU) and has been aimed at x86-based embedded system development. This 4x4 inch development board is capable of running Android, Linux, RTOSes and Windows.
The Gizmo board includes G-T40E dual-core processor which clocks at 1.0 GHz along with AMD Radeon HD 6250 discrete-class graphics. The board has a performance capability of 52 gigaFLOPS at uses less than less than 10 watts of power. The detailed technical specs are as follows:
<ul>
[*]AMD Embedded G-Series APU
[*]AMD A55E Controller Hub
[*]1GB DDR3 SDRAM
[*]JTAG header for SmartProbe® development & debug
[*]Low and High Speed card edge connectors for expansion
[*]Graphics â VGA display connector
[*]Ethernet RJ-45 port connector
[*]USB â 2 standard type A USB connectors, pin header w/ 2 USB connectors
[*]SATA â one connector
[*]Audio â Line-in, Line-out and MIC signals
[*]Power â 12VDC power supply with cables
[*]Size â 4â x 4â (10.16 cm x 10.16 cm)
[*]High Performance: 52.8 GFLOP Capacity
[*]Low Power: APU 6.4W TDP
</ul>
The board is available as a part of a development kit on the GizmoSphere website for $199 (10,706 INR).
Source:Â #-Link-Snipped-# and #-Link-Snipped-#
