@thebigk • Jan 1, 2009
shubhadha bhatHi all,I'm an instrumentation engineer. I'm working on oil and gas instrumentation-fresher. I need some guidance regarding Front end engineering and Design & detailed engineering in oil and gas instrumentation.
Sure. What information do you need? Could you please ask specific questions? ๐
@sauravgoswami-UAfTlI • Jan 2, 2009
As far as i Know ,lot of instrumentation is required in oil and gas,the favourite being the flow-meters!!!!!anyway,what you are searching for???
@shubhadha-bhat-xgJqss • Jan 2, 2009
Currently i'm working on one project. In this project v r creating index for instruments- I/O category, Instrument tags, Signal level etc., I think this is part of front end engineering and design(FEED), what are the other things we do in FEED. After FEED then we go into Detailed engineering. In detailed engineering, we assign junction boxes, Multicore cable etc., I need to know what are the other things we are supposed to do detailed engineering.
@shyla-r-nIEchU • Jan 2, 2009
Hi all, Is there any opportunity for freshers in instrumentation to work on any part time projects in oil and gas, and will these type of projects help in getting gud job in the same field...??
@sauravgoswami-UAfTlI • Jan 3, 2009
@shyla,i appreciate your keenness,I will apreciate more if you can answer the post,and ask appropiate questions were they are suitable
@shubhadra : Following are required in detail engineering
๏ง I/O list
๏ง Logic Diagrams
๏ง Control Room Layout
๏ง Instrument Location Layout
๏ง Cable Schedule
๏ง Interconnection Schedule
๏ง Junction Box Schedule
๏ง Instrument Loop wiring
๏ง Vendor Engineering review
๏ง Factory Acceptance Test of DCS
๏ง Inspection of Field Instruments, Control Valves etc.
dont hesitate to ask!!! -
@shyla-r-nIEchU • Jan 4, 2009
Saurav, That was very useful information. Here is my brief understanding regarding Detailed engineering, Please correct me wherever I'm wrong. I/O list consists of data regarding all instruments after acquiring those data Cable Schedule has to be done where we assign field cables after which Junction Box Schedule in which we assign junction boxes and multicore cables. After these steps we generate Instrument Loop wiring(which includes the field instrument, Field cable, Junction box number, Multicore cable number). could you brief me about Interconnection Schedule, Vendor Engineering review, Factory Acceptance Test of DCS and Inspection of Field Instruments, Control Valves etc. And also could you explain me what are the roles and responsibilty an entry level engineer normally does in the above mentioned steps.
Thanks in advance -
@immu-vQIhkK • Jan 9, 2009
Please i need some info about junction box. can i incorporate digital and analog signals in a same JB with same multicore cable or i need to seperate them. se4condly inputs and outputs are also needed to be seprated or not? my problem is that my plant is very small with small number of inst in a single JB(6-9 including both Inputs and outputs) what do you suggest?
@shubhadha-bhat-xgJqss • Jan 9, 2009
Hi Immu,
You can combine Digital and analog signals in the same JB and also Input and output signals can also be connected to the same however few exceptions are:
Power signals cannot be connected to the same JB where the instrument signals are connected, For Ex: Indicating lamp needs 24VDC Power supply, This Signal cannot be connected to the JB where(TT-temperature tx) signal is connected.
Also signals like AI/AO/DI-VF/DO-VF can be combined. but for power signal is indicated as DO-volt wetted-this signal cannot be combined with AI/AO/DI-VF/DO-VF. -
@immu-vQIhkK • Jan 12, 2009
please can u tell me what is difference between wet contact and VFC mean. nad why we need to seperate them
@shyla-r-nIEchU • Jan 14, 2009
Volt free contact does not provide voltage, just provides open/closed condition- for ex: limit switch. In volt wetted contact there is a voltage that is passed accross- for ex: for excitation of solenoid valves volt wetted connections are provided.
Since voltage levels vary for volt free and volt wetted we have to seperate those signals, main reason being to avoid the interference between those to voltages.
@pikachu-nFbG7i • Feb 4, 2009
Hi, I just joined... hope to learn something here... what about relays.. if i am not mistaken, all dry contact, we use relays.. what is the actual usage of relays???
@sauravgoswami-UAfTlI • Feb 5, 2009
actual use of relays is to convert electronic signal into mechanical signal....and thus operate on specific instruction in realtime environment
@pikachu-nFbG7i • Feb 25, 2009
Hi, Thanks for your reply. Can I say that each devices have their own specific relays???
@sauravgoswami-UAfTlI • Feb 25, 2009
Relays are classified depending upon their functions!!!
@instrumentlover-LrN2Wd • Mar 30, 2009
Dear Members
Im working in GAS Plant as a QC INSTRUMENTATION INSPECTOR, I want to learn FEED and change my career as Instrumentation Engineer, Pls provide me the best resources to learn.
Waiting for your reply
You can mail me @ <removed by admin>
Regards
Nazeer -
@sauravgoswami-UAfTlI • Mar 30, 2009
active participation is expected,you will get the resource for yourself!!!
@jarniel-aAYIAe • Apr 24, 2009
shubhadha is correct, You needed new I/O for the new terminal that you want to add it is not necessary if you have old JB that you can still use for new connections. But you have to terminate new lines.You can add but you cannot adopt.correct me if im wrong.
sauravgoswamiactual use of relays is to convert electronic signal into mechanical signal....and thus operate on specific instruction in realtime environment
What those is means? As far as I know relay is a component or an accessories that switching or giving signals between N/O or N/C to drive or to give access to their designated loads.๐ correct me if im wrong.
