Frequency Counter - Need Help
atlas
@atlas-LIgRCK • Oct 22, 2024
Hi people,
I'm a student at MIT at the moment and I’m going to utilize the GPIO-24 – #-Link-Snipped-# produced by Diolan, Ltd. – as a part of my project. The adapter (or, to be more precise, the frequency counter) will be used to measure the speed of a vehicle.
The frequency counter should measure the frequency. I’ll use this value to calculate the speed and output it.
So, I want to use the input to somehow influence the output.
How can I do it?
Any advice is appreciated!!!
  • relto
    @relto-tkTLnK • May 27, 2010
    Hello
    Have you looked at DIOLAN description of the #-Link-Snipped-##-Link-Snipped-#?
    I hope this will help you to get started.
  • atlas
    @atlas-LIgRCK • May 30, 2010
    Yes, I’ve read their description of freq module. I quite understand how it works.
    The question is: how can I get the frequency value stored in freq counter to generate the speed?
    Ideally, I want to do some math to the frequency and then output the calculated speed.
  • relto
    @relto-tkTLnK • May 31, 2010
    Use this command #-Link-Snipped-#. What’s the problem?
  • atlas
    @atlas-LIgRCK • Jun 1, 2010
    Good solution.
    I send this command periodically to obtain the freq and calculate the speed.
    Meanwhile, the problem is that: I want the freq counter notify me the exact moment when some fixed speed limit is exceeded.
    How can realize that?
  • relto
    @relto-tkTLnK • Jun 1, 2010
    The usb gpio interface adapter gpio-24 supports event-driven interface. The frequency counter may notify you when your speed limits are reached. See here #-Link-Snipped-# and here #-Link-Snipped-#. This method is ok, assure you.
