Force required to compress air in cylinder
Amith Gupta
@amith-gupta-8xdMSE โ€ข Oct 24, 2024
Need help with this
.. Suppose I have a cylinder with plunger arrangement on one side and the other is blocked.. and when i push the plunger the air compresses.. Can anyone suggest me formulas to calculate how much force or work done to compress the air..
  • ISHAN TOPRE
    @ishan-nohePN • Jan 13, 2011
    I think its same as pv=nrt;
    once you get pressure multiply it with CS area.
    Is there any other opinion?
  • Amith Gupta
    @amith-gupta-8xdMSE • Jan 15, 2011
    ishutopreI think its same as pv=nrt;
    see.. as the compression process is being performed the density of the air inside the cyl varies.. so thats the problem . Coz less dense air will transfer less force while denser air will transmit greater..
    Any suggestions are welcome
